Hey mates.
Well i have one issue, i swaped Volvo v70 2.4D 120kw automatic 05 year to manual.So far all was fine but then i have some kind of questions, seems i cant find answers.
So car wont start from ignition key and if you go engine room and put straight from starter it goes well.Then there shoult be a Starter interlock wiers in gearbox wiers, but wich color/what pins they are if some has expirence with such thing.
It will be better if some has some kind of plan/diagram for it.
Cheers from Estonia!
Thanks.
Volvo V70 2.4D 120kw swap atm to manual.
- RickHaleParker
- Been thanked: 978 times
On the wiring harness that went to the automatic transmission, locate the Blue-Yellow wire and connect it to ground, the Brown-Black wire on that harness is the ground the interlock switched used.
Active
Past
Past
- JohnDeere
- Year and Model: 2005 V70 AWD
Thanks man workt for me!
Also do you have any idea about cuting off automatic module? And last thing is cluch pedal position sensor wiers, beacuse for automatic they dint put extra wire for clutch sensor, where under where i shoult connect it as well?
And what kind of colors are for reverse light if you know or i need to put extra new cables for it?
Many thanks.
Edit: Cluch pedal position sensor*
Many thanks.
- RickHaleParker
Wires from the Clutch Pedal Sensor run to the ECM pins B4 and B15.
7/123 is the Clutch Pedal Sensor.
Active
Past
Past
- 2113 Views
Last post by volvolugnut
- 2233 Views
Last post by skloon
- 21 Replies
- 11903 Views
Last post by polskamafia mjl
- 2261 Views
Last post by henrysin44
- 1427 Views
Last post by dha89
