2013A XC90 - Exhaust after POR-15 44316 Aluminum High Temperature Paint
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
An effort to feel good when I'm hovering underneath on my creeper.
nedc
Year and Model: 1994 940T
Post by nedc »
Sprayed on or brushed? Looks good-I'd be curious to know how it holds up over time.
xHeart
Post by xHeart »
Brushed. Paint this thick. I usually paint a thin layer and let it cure overnight. Our roads are salted during winter months. Washing undercarriage helps. Another coat in 3-4 years.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
How much does it cost?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
xHeart
Post by xHeart »
E Showell wrote: 04 Mar 2020, 21:16 How much does it cost?
The can is good for several coats https://www.amazon.com/POR-15-44316-Alu ... B00J6C1C5U
xHeart
Post by xHeart »
Another example of DIY our 1997 850 exhaust pipe after a short lived $800 repair by a local muffler shop (all talk)viewtopic.php?f=1&t=61022&start=40
xHeart
Post by xHeart »
The salted roads will be here any day now. A preventive maintenance of undercarriage helped look closely at the Exhaust Muffler -- section after CAT. After a wire brush cleaning, the aluminum wrap appears deteriorating and peeking off -- a putty knife slides an inch or so and stops. How to slow down deterioration?
Here are 2 pix:
E Showell
Post by E Showell »
Soak the expletive out of it with Fluid Film sprayed from a rattle can. You could also use Woolwax, although I have never used it. Fluid film smells like sheep. Woolwax isn't supposed to have much odor.
'95 855 auto (sold)
E Showell
Post by E Showell »
Just be aware that I don't know the flash point, if any, of Fluid Film and exhausts can, as you know, get quite hot.
'95 855 auto (sold)
xHeart
Post by xHeart »
E Showell wrote: 02 Jan 2021, 16:25 Just be aware that I don't know the flash point, if any, of Fluid Film and exhausts can, as you know, get quite hot.
The aluminum wrap is likely to come apart at the seam first. To close the tear and prevent the seam from further rip, the muffler may need some tape like material that is heat resistant.
A quick search shows Titanium Exhaust Warp Kit, any thoughts?
