IPD Subframe Bushing Inserts
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Has anyone installed any of these subframe bushing "reinforcers", for lack of a better name?
https://blog.fcpeuro.com/how-to-replace ... ng-inserts
Do they work?
Do you just tap them in with a light hammer and then reinstall the washer/bolt/etc.?
Or should I forget that whole idea and go for a real bushing replacement? Is that a difficult task? Special tools required?
Thanks in advance.
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Did you also read the reviews on their site? https://www.ipdusa.com/products/8969/12 ... insert-kit
They have a installation video on that by the way.
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
chrism
Post by chrism »
Thanks for the links, ND.
Even if the things didn't last forever, the simplicity makes it rather attractive.
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 6 times
Been thanked: 4 times
Post by dlundblad »
My concern would be subframe bolts breaking and really being SOL.
Hers: Charcoal 2002 S60 2.4t 187k
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
I installed them and felt the difference immediately. It wasn't as transforming a feeling as a set of new shocks but it was there.
Apply a bit of the lube and tap away as you posted. I used a heavy hammer and very little force.
The bolt and washer brought 'em home, as you posted.
My existing bushings showed no evidence of deterioration. I guess that facilitated ease of installation as the holes hadn't collapsed.
The bolts are quite large. Mine required a bit of wire brushing as they were dirty (white powder) upon removal.
Do report back when it's all done.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
I want to add these after I've done some other basics. Then ipd sway bars. I hate lean.
