- Has thanked: 1611 times
- Been thanked: 4075 times
The performance advantage of copper plugs is that when you replace them in 30k miles, they will come out the head, while the 7 year fancy metal ones will create a bad weekend of bad words.
- June
- Has thanked: 523 times
- Been thanked: 261 times
I see I'm not the only one who defies the law of gravity!
Great photos! Did you order a starter and mashed potatoes, or a flywheel pizza???
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Once I remembered I was in P4 instead of Garage C, I found her.
I need to make some friends in NJ. $40 a day to park..
The only issue I've had with gravity is my furniture...my chest fell into my drawers...
If I keep Elizabeth at a GPS 60 mph on 93 octane, she flirts with 30 mpg
- Has thanked: 317 times
- Been thanked: 531 times
Yeah, I really like these wheels! I found them on a C70 at the junkyard with a good set of matching tires, so it worked out since I needed tires anyway!
If I lowered this car they would look even better. When I have a heavy load in the back the rear wheels fit so much better against the wheel wells.
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
I lowered my 850 by 35mm and it does make a big difference as you say. On the plus side, and if you get good springs that are matched, I've also found that the ability to carry heavy loads is not diminished and actually that the ride when fully loaded is improved over stock - probably due to slightly more progressive damping rates.bmdubya1198 wrote: 09 Feb 2019, 08:11Yeah, I really like these wheels! I found them on a C70 at the junkyard with a good set of matching tires, so it worked out since I needed tires anyway!
I've been doing a bit more research (got to entertain myself somehow as I get dragged around garden centres!) and it seems the platinum-iridium plugs are the best to get, due to the greater efficiencies and lifetime (approx 25% greater life) than the double-platinum plugs whilst retaining the same high temperatures that help to decrease fouling build up.Cookeh wrote: 09 Feb 2019, 02:49Great information, thanks for taking the time. I've now seen a mix of platinum-iridium and double platinum being cross-referenced with the OE Champion plug, does anyone know if there is a performance advantage to one or the other?
- June
OUCH! that must have hurt!abscate wrote: 09 Feb 2019, 07:41
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Volvo, the part that is still Swedish, makes jet engines. Or at least they used to. So it should be possible to fly partly Volvo.June wrote: 09 Feb 2019, 09:49OUCH! that must have hurt!abscate wrote: 09 Feb 2019, 07:41
I've had other issues with gravity
! It's hard to drive "Baby" 60mph. She is much happier at 80 minimally. It must be the T6 in her! I'm so happy you are back safely! I'll fly in the air when Volvo makes airplanes
. June
- June
I wonder which airplane manufacturer uses them? If Volvo made the whole Jet Plane it would undoubtedly be the safest, best built plane out there. Boeing used to have the best jet, the 707 and 747. Once the 707 disappeared from Delta Airlines, I have not flown since. JuneRattnalle wrote: 09 Feb 2019, 09:53Volvo, the part that is still Swedish, makes jet engines. Or at least they used to. So it should be possible to fly partly Volvo.June wrote: 09 Feb 2019, 09:49OUCH! that must have hurt!abscate wrote: 09 Feb 2019, 07:41
. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
Time to hop into a Saab!
Yeah, when I've got really heavy loads it gets REALLY low. That's what I like about my dad's E39 wagon, it has air self leveling suspension, so it never gets that low.Cookeh wrote: 09 Feb 2019, 09:13 I lowered my 850 by 35mm and it does make a big difference as you say. On the plus side, and if you get good springs that are matched, I've also found that the ability to carry heavy loads is not diminished and actually that the ride when fully loaded is improved over stock - probably due to slightly more progressive damping rates.
This was my V70 with around 600 pounds of scrap metal in the back... somehow it didn't rub! And I had two people with me!
- June
I'm too old to switch now! Besides my Volvo has Jet power under the hood
My Volvo cars owned
1996 960 ordered
1996 960 ordered
