Hello,
This is my first post and I must say it's nice to find this website and get feed back from fellow Volvo owners.
Here is my saga, My 04 v70 2.5t serpentine belt broke after replacing it I noticed that my REP light came on and the car would not accelerate. I did have a friend check it out and he claims that the A/C compressor need replaced and that is what is causing the REP issue. Is this the problem or ?
Please help a bloke out that doesn't have much money.
Thank you
Scooter
Reduced Engine Power indicator light
scooterdewd
- Year and Model: 2004 v70 2.5t
- SuperHerman
- Been thanked: 207 times
Take off the serpentine belt and rotate the A/C compressor pulley. If it is frozen then yes this could be the problem. With the belt off, you can run the car off the battery for a few minutes, charge it up afterwards. If the REP warning disappears you have your answer.
I assume your car is making a rather loud belt related noise??
NOTE and be AWARE: Without the serpentine belt you will not have an alternator, power steering and A/C as these are all powered via this belt. You will also get a battery related warning light.
- Has thanked: 1613 times
- Been thanked: 4075 times
The AC pulley should freewheel easily with the belt off. Without the alternator turning the battery will go low quickly and give that error.
- 22 Replies
- 25401 Views
Last post by cn90
- 5179 Views
Last post by Raindog92
- 499 Views
Last post by PatternFlyer
- 13 Replies
- 1638 Views
Last post by firstv70volvo
- 1995 Views
Last post by precopster
