No spark after distributor
Rubenrodri126
- Year and Model: 1997 850 t5
Ok i replaced the head gasket on my volvo 850 1997 i put all together but for some reason i dont have spark after the distribuitor i mean i took the cable of the coil of and i have spark but nothing at the spark plugs i have fuel compresion and its on timing before i took the car apart it was running perfect any suggestions??? Please help
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Are you using new parts for the ignition such as cap, rotor, cables and plugs?
The reason I am asking is that if you don't there may be something wrong with the old cap, since you you have spark going to it but not from it. So the cap would be my first suspicion.
I hope you get it running soon,
Dirk
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Year and Model: Many Volvos
- Been thanked: 76 times
If you are sure that you don't have spark at the plugs but do have spark at the coil it pretty much has to be the distributor cap and/or the rotor.
If you removed the wires from the distributor make real sure that they are reinstalled in the proper order. Both Haynes and the factory service manual have them labeled incorrectly.
The correct order is here:
Volvo 5 cylinder engine firing order
Rubenrodri126
Yes cap rotor wires and plugs i gap all the spark plugs to 25 wires are the same cap and rotors i took all apart again and inspect them all look perfect no cracks or nothing no crack wires
Rubenrodri126
When I took everything apart I number the cap and the wires in order so I don't get it mixed I put them on the order that I had I check the photo that you post and both are the same rotor it's in good condition and also in good condition I bought it like 2 months ago
- Has thanked: 312 times
- Been thanked: 818 times
Check the circular, black metal brackets on the back end of the cams, there is one under the cap and there is a different one under the cam sensor. It is possible to put them on wrong and then you can get no spark.
It's also possible for the electronics inside the rotor to go bad, then you get no spark through the rotor. But sounds more likely related to the engine work, check those brackets.
Rubenrodri126
Okay I'll try to check that apt I got the car to run a few seconds dad died and now I don't have any spark even at the coil or nowhere
No spark from the coil is one possible result of a bad cam sensor. Could be the plate, could be something else. Worth also checking the cam and crank sensor connections.
Rubenrodri126
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The sensor wheel you are holding has been put on wrong. There should be two tabs sticking up. The tab to the right has been flattened by it being on top of the cam end instead of down in the slot ground on cam end. You might be able to pry that tab up and fit it correctly.
- 2309 Views
Last post by Sommerfeldt
- 49 Replies
- 10923 Views
- 3136 Views
Last post by Roger_850T
- 3400 Views
Last post by ndphotonl
- 1973 Views
