Has thanked: 1500 times
Been thanked: 3812 times
Re: What did you do to your Volvo today? (now Sticky!!)
:lol: :lol: :lol:
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Is that your dinner for tonight?
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
They taste like chicken. I didn't like it at first, but it warren-ted a second chance.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 01 Mar 2019, 07:28 :lol: :lol: :lol:
I think you got it mixed up :lol:
Just ordered a crap load of parts yesterday, ordering more today. Once I take care of a couple other things I'll be ordering the tune from Hilton. She's gonna be terrorizing the streets soon! :twisted:
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Did my motor mounts on '94 850. Couple of the comments I'm sure have been said before. Radiator cooling fan asemmbly has to come out and I've seen some tutorials not mentioning removal of the upper engine torque rod, this is not mandatory, but would be helpful in keeping the engine level while raising and lowering. To make sure you keep the engine level I would recommend using two jacks ( one under oil pan, one under trans). The other thing about only raising the engine 24 mm, good luck with that. Anyway mounts are in and I think my front one was still good and probably original, the rear showed some signs of leakage. Car seems to ride and shift a lot smoother now. This was a relatively difficult job and would put on par with rear delta link job. Picking a day that was 28 degrees out and snowing didn't add to the happiness of doing this job, but the result was worth it.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
GlennG2759 wrote: 02 Mar 2019, 07:26 Did my motor mounts on '94 850. Couple of the comments I'm sure have been said before. Radiator cooling fan asemmbly has to come out and I've seen some tutorials not mentioning removal of the upper engine torque rod, this is not mandatory, but would be helpful in keeping the engine level while raising and lowering. To make sure you keep the engine level I would recommend using two jacks ( one under oil pan, one under trans). The other thing about only raising the engine 24 mm, good luck with that. Anyway mounts are in and I think my front one was still good and probably original, the rear showed some signs of leakage. Car seems to ride and shift a lot smoother now. This was a relatively difficult job and would put on par with rear delta link job. Picking a day that was 28 degrees out and snowing didn't add to the happiness of doing this job, but the result was worth it.
Where abouts are you upstate? Wondering if you're in range of the Albany Volvo meetups that occasionally occur.
850 LPT
Post by 850 LPT »
Yesterday I finished installing the new starter on the 850 and it went really well. I think I'm getting quite comfortable tearing into the engine compartments of these cars. I found taking out the fan with the shroud together as an assembly works well. Easy to do and provides a lot of space.
While I had the car in the garage, I also fixed the horn problem and installed new insulators. That was a fun little project. When I bought the car last spring the horns were disconnected, so that gave me a pretty good clue about why they were not working.
I wanted to get all this done because my daughter wants to drive this car on her driving test next Saturday, but that ain't happening.
Because as a reward, I was greeted this morning with a complete no start situation. The engine tried to catch for 2 seconds and then it was dead, fun stuff. Basic troubleshooting time I guess...
And, to top it off... ha, the top off the dipstick broke off.
Another little project right now is trying to figure out if my car has a remote receiver, and if yes, which one. Once I figured this out at least I know which remote fob to get.
Dirk
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 36 times
Post by theWIFES_S70 »
Reset the "Service" light for the third time! Hello Chinese Volvo Service Reset Tool, baby! Hope everyone is good!
Retired:
2015 Volvo S60, T5, 85K
bmdubya1198
Hopefully picking up another Volvo today. Wish me luck!
Also hopefully getting my new radiator today... whenever FedEx decides to get moving...
Is it another Rabbit?
