My car has a rough idle and u feel it in the foot pedla and it is when im at a stop light in drive and almost like it occastionally feels as if it has a hiccup every so offten.. NO CEL
ITS ALMOST AS IT its jumpy and the idle alway remains the same around 800
Did the spark plugs awhile back to..
But its Almost as if it’s miss firing but wouldn’t my car throw a code if I was getting misfires
CAR IDLES rough //No CEL Topic is solved
natural4reelz
- Year and Model: 02 VOLVO S60 TURBO 5
- Has thanked: 3 times
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
You might have to dig in and clean the throttle body; no need to remove it, just unscrew the air intake pipes to get to it. If not, then see if the engine mounts are dried up and loosing their rubber.
natural4reelz
The top mount
Is bustedm
The idle always stays the same and i feel vibration and sometimes a little jolt or HICCUP on the GAS PEDAL A
It almost feels like its misfiring
And it is using alot of gas
Is bustedm
- Been thanked: 4068 times
If you have an erratic misfire it won't throw a code, and even if it does, you can trust the cylinder code about 1/2 the time.
- June
- Has thanked: 523 times
- Been thanked: 261 times
If the top mount Is damaged, then likely the lower mounts are bad too. Busted engine mounts will cause engine vibration like you described. The question is whether the hiccups is the engine moving around or something else like the ac compressor kicking on and off. If the engine was to misfire it would throw a code. Also these cars are fussy about aftermarket spark plugs. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
natural4reelz
Volvo spark plugs got them from FCPEURO
- 19 Replies
- 3557 Views
Last post by Chapelgirl
- 1774 Views
Last post by jimmy57
- 1512 Views
Last post by valvolvo70
- 544 Views
Last post by fiore67
- 1872 Views
