I discovered stripped spline on windshield wiper arm (driver side) today. I tighten the nut (pilot nut would be a better design) but I am not sure how long will it last.
If my wiper fail again what should be my next step before I need to replaced the entire assembly. Are there any spline inserts?
Would Loctite help?
stripped splines on wiper arm
Loose Volvo Wiper Arm Fixes
- Year and Model: Many Volvos
- Been thanked: 76 times
I would just replace the arm. FCP Groton sells them for around $35.00.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Or one in good shape from a junk yard.
januwan
- Year and Model: 97 850 NA 209 K
- Has thanked: 7 times
- Been thanked: 3 times
I guess, I forgot to mentioned that the mating spline (on the shaft) is also damaged so it is not only arm but the entire assembly.
How difficult it is to replace the entire assembly?
Thanks
Thanks
januwan
As a temporary fix...try covering the splined shaft with some layers of "Tin Foil" and then tighten the wiper arm down over it. The number of layers to get a tight fit will vary depending on how badly the splines are worn. You may have to remove some foil at the end of the shaft to make sure the arm seats deep enough. Then tear away any excess tin foil when finished.
That should keep you going in the rain or snow until you get the parts to replace everything.
Cheers,
FRED
Cheers,
FRED
1997 850
2007 S40
1998 E300 TD
1969 Austin Mini
2007 S40
1998 E300 TD
1969 Austin Mini
I like Fred's idea, but I think tin foil may tare and be a little bulky. Same idea, but using the white tephlon tape that's used on the male end of a garden hose spicket to keep the garden hose from leaking. Not exactly sure what it's called, but it's strong, and will fill up nooks in the splines that may have broken off. You'll probably have to put several layers as it is thin, yet customizable for thickness. Never tried it, just a thought.
About four years ago I had the same problem and fixed it and it is still holding up. Take out the nut holding the arm in place and take a good look at the end of the attachment point of the arm to the mechanism. Try and find a washer that is at least 1mm thick, with a diameter that exceeds the diameter of the hole on the wipper arm by about 1mm. Put it there, place the nut and tighten. The washer will force the arm assembly further down on the spindle and it will hold up nicely.
Good luck!
Icelandic
Good luck!
Icelandic
1995 859 auto NA
I'm a novice here but since I have the same problem, here's what I thought to do: use a helicoil to relace the worn spline in the arm. Actually, I think I caused the problem by not knowing how to properly remove and replace the arm. Can someone tell me how to do it right so I don't cause the same problem again, please? Thanks.
squeaky3
squeaky3
Richard Manson
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
Look at this post for arm removal.
https://www.matthewsvolvosite.com/chat/p ... hp?p=53332
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
