Built a little code reader for sorting out my no heat issue, but the LED just stays on, no blinks when switched on.
It’s a 12v, and there’s a resistor, when my switch is turned off it’s off when plugged into the correct spots on the OBD output.
Ideas? Needs a different resistor?
I don’t need the heater yet, but it’s humid in Louisiana, and it would be nice to have defrost in the morning
LED code reader/ECC help
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
Sorry to hear you're having trouble getting the codes to read. What is the resistance value of resistor you're using? Which pins are you plugging the code reader into?
I got good results with the circuit shown below, plugging the switch between pins 5 (GND) and 6 (ECC) and the positive side of the LED into pin 16 (+12V). I used a 5K Ohm resistor in line with the LED to prevent overcurrent thru the LED.
viewtopic.php?f=1&t=50443&start=13
- RickHaleParker
- Been thanked: 958 times
The led flash code readers are for Fenix 5.2, Bosch LH 3.2 Jetronic & Motronic 4.3.
They don't work on Motronic 4.4 or Motronic 7.0.
Your 2009 has Motronic 7.0.
Peevarino
- Year and Model: 2009 XC70, 97 855R
- Has thanked: 28 times
- Been thanked: 3 times
Unsure, it’s got heat shrink over it, but I’m pretty sure that’s the issue. It’s a 12v rated led, assumed (poorly) it would work fine.jreed wrote: ↑05 May 2019, 06:00 Sorry to hear you're having trouble getting the codes to read. What is the resistance value of resistor you're using? Which pins are you plugging the code reader into?
Those are exactly the pins I was using.
I posted in here because it’s for a 97 850, not the 09 I have listed in my profile.
09 XC70 3.2
97 855R
97 855R
- RickHaleParker
Motronic 4.4 started showing up in some '96 850s.
"97 is pretty much the year they moved to Motronic 4.4.
- RickHaleParker
Pull the cover off the ECM box and get the number off the ECM, the number you are looking for is in the format "0 261 20X XXX" .
- jreed
For what it's worth, the LED code reader works OK on the ECC in this car.
I'm not sure if I've got Motronic 4.3 or 4.4. I think it might be a 4.3.
I've got a '97 855 GLT wagon and the ECU is a 0261203936.
- 2810 Views
Last post by Sommerfeldt
- 2259 Views
