No Oil Pressure - Stop Engine
Been thanked: 4065 times
Nice catch on the PCV orangex. That’s completely plugged, at the red circle.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
That may then explain the sludge in the oil. I'm also in Canada and never seen such sludge at the oil change, and also do small distances (+ I use basically the same oil) - but my PCV works fine.
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
Thank you guys for this is precious information.
Now, how do I clean the PCV, if the hole you circled is clogged, that it easy to clean, but where do I start to clean the whole PCV? Is it difficult to do?
Also, apologies for the question, but I never worked this area of my car, it is all new to me, where is exactly the inlet mesh you refer to?
Thank you,
Alex
Polar 940 Turbo SW - 1997
oragex
Post by oragex »
For the pcv job on a turbo engine, there are a few write up and also a few videos on Youtube. Good to write down the few special tools needed (usually a wobble joint 1/4" size if I remember) and the few difficult parts such as the ptc nipple (I think there is a recent post with a helpful trick on this). Parts from sites like fcpeuro are not that cheap but it's recommended to replace all hoses (plus gaskets and hardware). Also a good moment to throw in a new thermostat
Metallo
Post by Metallo »
Oragex,
I have cleaned the oil pan, including the clogged PCV hole. Since I am going to clean/replace the PCV, should I first re-install the oil pan and then work on the PCV or is there a benefit to remove the PCV without the oil pan in place?
Also, you asked this question:
The inlet mesh, can you undo the whole pipe? I would just try a water hose on the other end, gently.
Where is the inlet mesh you refer to?
Thank you,
Alex
Alex, it’s the pickup mesh , like a grill, where the oil pump picks up the oil in the bottom of the sump. It should be on the bottom of the thing sticking down from the engine block. It stops the pump from sucking up big pieces of oily rubber ducks floating in the sump
Metallo
Post by Metallo »
Abscate,
Thank you, I have already removed it, it is also clogged, so will it work to soak it in hot water and degreser?
Also, although the PCV Nipple P/N 30731007 is for the S60, I believe I should be able to use it for my XC70, but I am looking for a confirmation here.
Thank you,
Alex
Been thanked: 504 times
Post by cn90 »
The PN 30731007 is $40.
All you need is:
- Clean the old banjo connection hole. No need to d/c the coolant side.
- Get silicone hoses with appropriate diameter (maybe 3-4 mm in size) and change the plastic pipe portion.
- The barb fitting can be re-used.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Metallo wrote: 19 May 2019, 04:51 Also, although the PCV Nipple P/N 30731007 is for the S60, I believe I should be able to use it for my XC70, but I am looking for a confirmation here.
Volvo P/N 30731007 is for the 2.9L used in S80 1999-05 | XC90 2003-05.
Active
Past
Metallo
Post by Metallo »
That is what I am saying, but it looks like it works for the XC70 too, has any body used it yet?
