No Oil Pressure - Stop Engine
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Nothing like the 30731007 on the 2006 XC70.
The only thing that is remotely like 30731007 on the 2006 XC70 is Crankcase Breather Pipe Assembly which is P/N 30731068 and cannot be confused with 30731007, they look quite different.
30731068 is used on on the 2005-2007 XC70 and the 2005-2009 S60.
30731068
Active
Past
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
I am aware of the original P/N, but the price is ridiculous which is why people find alternatives.
Now, I am sure I read somewhere that the 30731007 can be used on the XC70.
I will try to find the source of this information and post it here.
Alex
Polar 940 Turbo SW - 1997
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
About leaving the oil pan out when working on the PCV, one advantage may be it's easier to clean well the oil drain channel to the oil pan that was clogged - this channel goes up into the block and into the PCV box. And who knows, maybe after 1-2 days you may want to check another thing at the bottom of the engine block, so it's perhaps good to put back the pan at the end of the PCV job
RickHaleParker
I found some references to savaging the Banjo hose barb from a 30731007 to fix a 30731068 but not much in the way of details.
Need to find a Banjo hose barb that will work. Take the dimensions and look for one on eBay.
Active
Past
Metallo
Post by Metallo »
In this moment I m stuck to remove the 17mm banjo bolt, I do not have a stubby wrench, so I guess there are no alternatives to remove it with an ordinary wrench, as I have no space to angle it. :(
RickHaleParker
If you are choking on the $200 price tag for the 30731068. MTC makes an aftermarket that goes for ~1/2 the prices. ÜRO makes a rebuilt kit to replace the hoses and clamps, go for ~ $50.00.
Count yourself lucky the Crankcase Breather Pipe Assembly on a 2.9L is $400.
Active
Past
Has thanked: 311 times
Been thanked: 817 times
URO rubber parts - no. Never.
Been thanked: 504 times
Post by cn90 »
Actually you don't need 30731007.
All you need is a silicone hose of appropriate I.D.
See the other thread I posted a question and someone answered it.
viewtopic.php?f=9&t=89648
RickHaleParker
Need three dimensions off the Banjo Hose Barb.
Active
Past
Metallo
Post by Metallo »
Hi,
I asked our friends at FCP if the PCV Nipple P/N 30731007 would work on the XC70 2005-2006 and below is their answer to my question:
Although not originally intended for the vehicle, it's been known to work well. The video we provided shows everything you need to know in order to install.
It looks like there are no changes needed other than following their video😁
Alex
