Crush washer?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 158 times
- Been thanked: 6 times
Thx XC70Rider. While I am on the topic can anyone tell me where the AT plug is? I will assume the oil drain plug is the one directly straight back and off to the driver's side of the oil filter but I am not sure where the ATF plug is.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
The large ATF drain plug is on the bottom right side of the AT facing the engine. If you don't have a 24mm wrench then a 15/16" will work. The crush washer is same size for both engine and AT drain plug. The ATF needs to fully warmed up driving via all gears before the drain. You'll drain ~3.5 quarts. Measure what comes out and add in new 3309 ATF via the dipstick.
For questions on which ATF to use or location of dipstick do searching on this forum. It's been discussed numerous times lately
Mr. Detail
Thanks much guys.
- Has thanked: 1611 times
- Been thanked: 4075 times
Are the P2 models the one that people inadvertently ruin their transmissions removing the wrong fill plug?
Not to make you snap to attention, Mr Detail
(He smugly posts with his array of manual transmission cars)
Mr. Detail
abscate,
Now you are scaring me. When abscate said "bottom ride side of the AT facing the engine", I am not even sure which square metal pan that is. Is he speaking of leaning towards the drivers side if the car?
- Been thanked: 504 times
Did you search for the DIY I posted?Mr. Detail wrote: abscate,
XC70Rider
viewtopic.php?f=9&t=89571Mr. Detail wrote: 22 May 2019, 11:30 abscate,
- 15 Replies
- 8872 Views
Last post by volvolugnut
- 2887 Views
Last post by dm635
- 655 Views
Last post by jonesg
- 408 Views
Last post by cn90
- 36 Replies
- 24940 Views
Last post by StickyPocket
