2005 XC90 T6 Executive Project Car.
- Has thanked: 316 times
- Been thanked: 531 times
Yeah, I'm curious as to how you're getting up to 7 PSI just by revving. Sounds like something is wrong.
- RickHaleParker
- Been thanked: 978 times
I am wondering if it is raw fuel burning in the Cat. Temperature goes up, gases expand. Basic principle of any explosion. Misfire cylinder X, start-up, does shut off Rear heated oxygen sensor control and Fuel trim.bmdubya1198 wrote: 27 May 2019, 16:31 Yeah, I'm curious as to how you're getting up to 7 PSI just by revving. Sounds like something is wrong.
If it was a clog in the exhaust system I would think it would jump to 7 PSI and stay there.
Active
Past
Past
That theory makes sense. It still seems strange to me though, if the cat is clogged, wouldn't it be harder for the turbos to build boost if the exhaust gases are getting backed up? Or maybe I've got it backwards and it's creating the load required to spool the turbos.RickHaleParker wrote: 27 May 2019, 18:22 I am wondering if it is raw fuel burning in the Cat. Temperature goes up, gases expand. Basic principle of any explosion. Misfire cylinder X, start-up, does shut off Rear heated oxygen sensor control and Fuel trim.
- RickHaleParker
A turbo is a windmill. Some of the Kinetic energy of the exhaust flow is transferred to the turbo, that is what spins the turbos. Of course you need enough exhaust flow Kinetic energy to do the work. That is why turbos only spin when you got a Kinetic energy surge such as when you are accelerating.bmdubya1198 wrote: 27 May 2019, 19:06 That theory makes sense. It still seems strange to me though, if the cat is clogged, wouldn't it be harder for the turbos to build boost if the exhaust gases are getting backed up? Or maybe I've got it backwards and it's creating the load required to spool the turbos.
Clogged exhaust would slow down the flow. Less flow = less exhaust flow Kinetic energy. Less energy to do work.
Not necessarily the Cat at fault, Resonator and Muffler can do it also.
Think of it in terms of energy transfers. A turbo recovers some of the wasted energy going out the exhaust system and transfers the recovered energy back to the engine.
The recovered energy can be used to improve fuel efficiency (LPT). Or produce more torque and power (HPT) .
Active
Past
Past
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
Following, I'll pipe up if I think I can help!
Not sure if this helps, but here is the 30636760 hose, not necessarily the seal...
https://www.fcpeuro.com/products/volvo- ... o-30636760
Or from Volvo:
https://www.volvopartswebstore.com/prod ... 36760.html
Looking at the parts diagram, I'm not seeing the part you posted a picture of...
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- RickHaleParker
That is what I am finding, $175 for the whole assembly. If nobody can locate replacement seals, I will do one of two things. Build up the seals with RTV or soak the seals in ATP AT-205 Re-Seal to recondition them. Still debating on which course of action.Roger_850T wrote: 27 May 2019, 20:14 Looking at the parts diagram, I'm not seeing the part you posted a picture of...
The seals have no apparent damage.
Active
Past
Past
- Roger_850T
Where do the seals go? I'm looking at the diagram, and I don't see anything that looks like the picture you posted. If you can point me at where the seals go, I'll keep digging and see what I can find...RickHaleParker wrote: 27 May 2019, 20:22
Roger
11 XC60 137k
05 XC90 V8 213k
05 XC90 V8 213k
- Roger_850T
Can you point at where it goes in this picture?
Roger
Roger
11 XC60 137k
05 XC90 V8 213k
05 XC90 V8 213k
- RickHaleParker
The red arrows are pointing to the location of the seals. The bulges off the main pipe are just clipped on. I know the diagrams show a different pipe.
Hum, I never checked the bulges for a separate part number ...
Active
Past
Past
- RickHaleParker
No separate part number for the bulges.
Picture with a bulge unclipped and the seal in place. Looks like resonator chambers or reservoirs.
Active
Past
Past
