2005 XC90 T6 Executive Project Car.
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
I'm at a loss. I can't find your pipes that bulge in the parts listing, the parts listing only looks like what I posted before. What's on the bottom of your "bulge" parts?
Other question: is you XC90 US Spec, or elsewhere? One would presume US Spec, since you're in Kansas, but sometimes one never knows...
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Roger_850T
Is there any volvo p/n on the plastic "bulge" part? Tha might help inform a cross-reference.
Roger
11 XC60 137k
05 XC90 V8 213k
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
It is "US Spec". Volvo AME partner group to be precise.
Go back to page 3. I think you missed a post.
Active
Past
RickHaleParker
Project put aside as I get the '98 C70 ready. She going to take the C70 to visit her brother who lives 1200 miles away in Virginia.
After that, I'm going with Option 2: Forge ahead on the engine, Plugs, PCV. Timing Belt service and possibly a new set of injectors. Deal with the exhaust system later if it turns out it is restricted.
Active
Past
RickHaleParker
Got the intake manifold off today. The Banjo is plugged up.
Ordered:
Volvo PCV Breather System Kit - KIT-P2XC90T6PCVK1
Six Bosch Spark Plug - Bosch FR7DC.
OEM Fuel Filter - Hengst 30636704
Set of 6 Remanufactured and flow matched Bosch 0280155831 fuel injectors.
While I'm waiting for the parts to, replace any questionable vacuum hoses, Clean the intake manifold, ETM charge pipes ... etc.
Active
Past
RickHaleParker
Went to change the Oil Trap on this 2.9 today. The lower bolt appears to be behind the alternator mounting bracket.
Can somebody that done one, confirm this is the case or tell me otherwise?
PS: Never mind, I found the notch in the mounting bracket that give one access to the Oil Trap bolt.
Active
Past
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
On the plastic intake pipe: On mine, with about 150k, while chasing turbo charger over boost issues, I found mine was also leaking a bit of air through the seals. For a short term fix I took copper wire and wrapped around the plastic so that the seals would compress. I bought a new part from the dealer for about $175.00.
During the process I learned that the type on our car is the upgraded part - it has the baffles. Apparently these are to lessen the turbo whistle as owners were complaining about it to the dealership. That said, one can source a used plastic intake pipe from an early model S80 which does not have the baffle, hence no seal. (I would not buy a used upgraded part as the seals most likely are no better). I read about one person who did the backwards design swap with success and liked the slight spool up sound. I just wanted the issue resolved so I bought the new part. If you have easy access to a wrecker it may be worth buying the early design - just make sure the rest of the plastic is solid, especially at the joints where it mates to the AL runners.
I did not find any reference to replacement seals. I also expect the design anticipates some leakage - otherwise they would not have used the seals. How much - who knows. I do know that before I had work done on mine I did not have any issues with the existing leakage - ultimately my problem was not the intake pipe, but the shop flipped my hoses around.
RickHaleParker
SuperHerman wrote: 05 Aug 2019, 15:35 On the plastic intake pipe: On mine, with about 150k, while chasing turbo charger over boost issues, I found mine was also leaking a bit of air through the seals. For a short term fix I took copper wire and wrapped around the plastic so that the seals would compress. I bought a new part from the dealer for about $175.00.
I'm thinking a light coat of RTV on both sides of the rubber seal to seal up the baffles.
There is a '04 XC90 T6 at the local PnP, no baffles, $21.00 for both.
Active
Past
SuperHerman
I would go the $21.00 route and be done with it. When I looked I was seeing prices around $50 plus shipping - so for the extra hundred and the fact I didn't want to have issues with a flunky part I bought new. You can always try the RTV if you don't like the "cool kid" whistle.
RickHaleParker
RickHaleParker wrote: 26 May 2019, 19:15 Fails Intake Vacuum test: No Vacuum, +3 PSI pressure with engine at 4000 rpm.
Medium size vacuum line broken, shares a tree with the intake manifold and the purge valve.
Active
Past
