HVAC fan stuck on low setting
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 6 times
Been thanked: 4 times
Post by dlundblad »
Just as the title says, the fan speed is stuck in a low position. It’s either notch 2 or 3. If you try turning it up, it’ll go from 3 to 2 then back to 3.
Before I go any further, does this sound like the blower motor resistor or something else?
Thanks.
Hers: Charcoal 2002 S60 2.4t 187k
dlundblad
Post by dlundblad »
Nobody has come across this issue yet?
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Does the fan speed up when using defrost or when turning all the way to hot or cold on the Auto-setting?
dlundblad
Post by dlundblad »
I want to say sometimes.
Been thanked: 504 times
Post by cn90 »
Could be bad HVAC panel too.
If you have a spare HVAC panel (? From junk yard), swap it to diagnose the problem...
dlundblad
Post by dlundblad »
I’ll give that a try. Thanks.
