What are these pictures of in my XC90 engine compartment?
racertim
Year and Model: 2006 XC90
Post by racertim »
I need help in identifying these two items in my engine bay. One is obviously broken and the other is a were that is not connected. Pictures attached. Thanks!
2006 XC90, FWD
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
#4 is the brake booster switch.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
If I recall correctly the top picture is of a harness holder which keeps the MAF connector anchored to the Airbox. You can fashion a zip tie to hold it or just install it as is.
racertim
Post by racertim »
I will look at it tomorrow in the light but I dont think the airbox has the MAF attached.
SuperHerman
Looking at picture 3 - I see the MAF attached to the airbox, but the connector is installed so it is not the MAF plug.
Is this the 2.5T engine?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Fuel pressure sensor connector but the fuel rail does not have the provision for a FPS. That fuel rail has the fuel pressure test port where the open end should be for insertion/attachment of FPS. Is your check light on? There should be a STC for open sircuit to the fuel pressure sensor, probably two DTCs as the temperature of fuel signal is also missing. The retainer clip on the harness lead would have been popped into the black plastic cover that is not present in the pictures.
racertim
Post by racertim »
Yes
racertim
Post by racertim »
That makes sense. Is there a good place where I can see a picture of what you are talking about?
Thanks!
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 126 times
Post by ggleavitt »
I had a minute, mid 2005-
05xc90 bay1.jpg (190.04 KiB) Viewed 2172 times
05xc90 bay2.jpg (193.08 KiB) Viewed 2172 times
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
Masscomguru
Year and Model: 2010 XC90 V8
Been thanked: 16 times
Post by Masscomguru »
Engine replacement? Looks slightly different.
