Tip/Trick: Wheel mounting alignment tool.
Has thanked: 292 times
Been thanked: 765 times
Re: Tip/Trick: Wheel mounting alignment tool.
erikv11 wrote: 12 Jul 2019, 12:24 And when you consider that on a P80 the "alignment pin" is basically useless even when there *is* one, this is a great tip.
P80 wheel lug bolts are M12 x 1.75, take that info to the hardware store ...
m12 x 1.75, 90 mm, head ground off
$3 for the bolt, 15 minutes with the angle grinder. Now it sits in the toolbox next to the 19 mm deep socket until the fall when I next need to move some wheels around.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
