I'm trying to remove the airbox on my 2009 S40. It looks like it is press fit, on the left and right, into the intake manifold with what looks like two rubber lugs. Is there a trick to removing it or do you just pry it loose? It also appears to be integral with the ECU box.
-Bruce
2009 S40 How to remove airbox?
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
I've only changed the air filter on my C30 which looks about the same but here is the diagram.
2.4 or 2.5 both looks like the same air box.
https://www.volvopartswebstore.com/show ... evel=24649
- MoVolvos
Thank you for passing that on. Very helpful. I've only removed the fresh air intake so I can get to the oil filter. Thanks.Brucebo wrote: ↑14 Jul 2019, 16:29 I found this! https://forums.swedespeed.com/showthrea ... ox-Removal
- 767 Views
Last post by SlipNSlide
- 1005 Views
Last post by Scoobey
