How to remove master window switch (2009 C70)?
Scoobey
Year and Model: 2009 C70
Has thanked: 3 times
Post by Scoobey »
Hi, helpful people! The driver side master window switch cluster on my '09 C70 seems to have gone bad. The windows all work when I raise/lower the top, the passenger side switch is fine, but the window switches, mirror adjustment, etc. on the driver's side don't. Question: how do I get the dang cluster out? I've pried, looked for screws and secret catches, etc., but it's not coming out. Do I have to remove the whole #@$!% door panel, or an I missing something? Thanks!
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
It is called the DDM ( Driver Door Module ). You got to take the door panel off because the bottom of the DDM is bolted to the door panel.
Active
Past
Scoobey
Post by Scoobey »
Thank you. Dang nab it, but thank you. :-)
