$10,000 S80 Challenge Topic is solved
This topic is in the MVS Volvo Repair Database » The $10k S80 Challenge
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
A few more pictures
pgill
Post by pgill »
All,
Here is my next update.
The air conditioning in my S80 wasn't getting cold enough.
It worked reasonably well at highway speed but not so well sitting at the traffic lights.
I hooked up my gauges to check the pressure and I found the following
AC set to max cooling
Low side pressure - 50 PSI
HIGH side pressure - 100 PSI
I checked my LR2 pressure as a baseline (Same engine and very similar A/C system)
Low side pressure - 40 PSI
High side pressure - 155 PSI
Ambient temperature was about 75 Fahrenheit for both vehicles (tested both within minutes of each other)
Looking at a chart for R134a revealed that my compressor wasn't creating enough pressure.
Unfortunately this means that its time for a new compressor.
I decided to go aftermarket and buy a Valeo unit
I did this because the A/C in my LR2 is still blowing cold and its two years older than the S80 and has similar mileage and it came new with a Valeo unit (Volvo specified a Sanden unit)
I also replace the dryer at the same time (in this case its just a bag of desiccant)
I didn't take any pictures but the desiccant bag is in the condenser and you have to remove the refrigerant and then take out the T-70 Torx plug (The plug is hidden by the radiator cross member so the radiator needs to be supported and the cross-member removed)
Some pictures
Vent gauge showing cooling but not enough (outside temperature was about 75)
The new compressor
The view from the engine bay with everything removed
At the same time that I replaced the compressor I also replaced the overdrive pulley.
I did this because the old overdrive pulley wasn't allowing the one way clutch action.
It was frozen in both directions.
After putting everything back together I did notice that the belt now moves easily in one direction (engine off) and it doesn't move in the other direction.
For the Overdrive pulley I decided to try Professional Parts Sweden (I will post here if it fails)
The old Pulley
Box for the new Pulley
With everything installed the AC is now very cold.
The Vent temperature gauge is in the shaded region.
And the low side pressure is about 35 PSI and the high side is about 150 PSI
I may need to add a little more refrigerant when it get hot.
Volvo recommends 800 grams
Land Rover recommends 730 grams
I am only running 640 grams right now
Cost
$376.52 Valeo 813271 A/C Compressor
$100.00 Remove old refrigerant
$29.85 New refrigerant
$16.86 GENUINE VOLVO 30776238 Receiver Drier Insert
Total cost for AC repair $523.23
Cost update
$7400 --- Purchase price
$62.53 --- (31401556) --- Booster O-rings
$16.36 --- (AISIN T-IV) --- ATF
$40.35 --- (DENSO 5344) --- Sparkplugs
$00.00 --- Filter housing
$51.47 --- (Mobil 1 0W-40, Oil and Filter)
$58.28 --- (LR006071) --- Thermostat
$00.66 --- (LR001505) O-ring for 30713530
$24.29 --- (30713530) --- Coolant hose
$23.99 --- (31439821) --- Coolant
$22.71 --- (14520, 14526) --- Michelin wipers
$68.85 --- (31272677) --- Oil Filter housing
$18.92 --- (LR006076) --- Idler pulley
$18.92 --- (LR006076) --- Tensioner Pulley
$08.97 --- (PK060473 CONTITECH) --- Aux Belt
$112.70 --- (LR021634) --- Motor Mount
$23.24 --- (30680474) --- Torq Mount
$20.95 --- (31390880) --- Cabin Air Filter
$15.76 --- (UD1306) --- Front Brake Pads (Amazon close out price, typical price is ~$75)
$523.23 --- AC repair
Total $8605.23
Remaining budget $1436.35
Take care
Paul
pgill
Post by pgill »
Latest update,
I forgot to include the cost of the overdrive pulley in my last price update so I am adding it in the update below.
I wanted to share what I found when I replaced the overdrive pulley on my LR2.
Comparing the picture for the S80 (Post Above) to the LR2 shows how clean the LR2 is in this area
This is likely due to the use of synthetic oil since new (Mostly Mobil 1 0W-40)
Also because I didn't take a side by side picture of the old part and new part, I am including one here.
One last disclosure, the part that I bought is an Overdrive Pulley not a Overdrive Decoupler Pulley.
The difference is that the Decoupler has a spring to dampen the belt movement.
Because the belt tensioner also has a a damper I decide to get the simpler part and see if it lasts longer than the original part.
Note: the part that I bought is also significantly cheaper.
Cost update
$43.37 --- Overdrive pulley ProParts Sweden 28436803
Total $8648.60
Remaining budget $1351.4
One more update, I don't get to drive the S80 very often but I did drive it once last week and it is running extremely well. The shifting is smooth and the engine is strong. I like driving it even more now as compared to when I purchased it.
Thanks
Paul
pgill
Post by pgill »
It’s been a year since I bought the S80
And I did have to do the maintenance (as documented here on MVS) that was neglected by the previous owner
Now that I am current on typical maintenance and repairs the car runs amazingly well
I could not be happier with my purchase
2010 S80 purchased on 11/5/2018 with 123,636 miles
As the picture shows I am at 135,012
And I haven’t done anything for months (ok maybe lexol on the leather)
Volvo did an amazing job with the P3 and the 3.2
And MVS is such an amazing site with so much great information that my S80 drives like a new car.
I remember reading a post from Matthew1 (the M in MVS) about the cost of used cars and the impact on hard working people. Hopefully this thread inspired someone to buy a P3. Because as I’ve shown the P3 isn’t that expensive if you can do some repairs yourself. And the P3 Volvo is a very safe car.
Take care
Paul
Been thanked: 4065 times
Well done Paul
You are driving a $60,000 luxury car on a $8000 cost, and you could probably get most all of it back if you chose,
pgill
Post by pgill »
abscate wrote: 29 Nov 2019, 16:31 Well done Paul
Abscate,
I completely agree its an amazing car for the $$$$.
If I ever sell it I would buy another P3 (3.2 or 3.0T)
Volvo did an amazing job engineering this Vehicle.
I swapped cars with my Son today, so I got to drive the S80 and he is driving my Audi 2.0T.
The power delivery is so nice on the S80
I do prefer the inline 6 cylinder.
Everything works in the S80
- Heated seats front and rear
- Rain sensing wipers (the sensitivity is easily set using the thumb wheel)
- BLIS
- etc.
The ride is so nice in this car.
The seats are extremely comfortable.
I am really glad that I got it.
If I ever drive the S80 to my mom's house (in Loudonville) i'll let you know, but its unlikely because I live about 3000 miles to the west.
Take care and stay warm
Paul
pgill
Post by pgill »
All,
It's been 6 months since my last oil change.
I decided to use a different oil, I was using Mobil 1 0W40 and I did have to add a quart during the 6 months of usage.
I decided to try Motul X-clean 5W40 (and a new filter)
And because I was going to be under the car I decided to replace 4 quarts of ATF fluid as well.
Here is the oil
And here is the transmission fluid
I prefer to use the AISIN fluid because AISIN is the manufacturer of the transmission
Cost update
$52.39 --- (Motul x-clean 5W-40, Oil and Filter)
Total $8717.35
Remaining budget $1282.65
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Pennzoil Euro 5w40 has been best in my situation of 8,000 miles annual oil and filter change each car. This winter will be my 4th -- oil level is stable where it use to loose a quart and more during the 6th month oil change cycle.
pgill
Post by pgill »
Xheart,
The Pennzoil Platinum Euro 5W40 is an excellent choice
It meets
MB 229.5
Porsche A40
VW 502
I would use that also without hesitation.
The only problem with the PP is the price.
I did a quick search and It costs about $13 per quart
I was using Mobil 1 0w40 European formula and paying about $5.50 per quart (Amazon sells it in 5 qt containers)
The Motul that I bought recently cost about $6.50 per quart.
If I can get the PP on sale I will try that next.
But first I need to see if my 3.2 consumes any of the Motul oil.
Take care
Paul
pgill
Post by pgill »
MVS Readers,
I decided to change the Wheels and Tires on my S80
I went from 17" wheels to 18" wheels
The tires I selected are Nokian Z-line A/S 235 45 18
I drove the S80 to work today and the new Tires suit the Volvo very well.
The most important part......the picture
I think the wheels make the S80 look younger than its 9 years of age.
Thanks
Paul
P.S. I will update my budget later to show the cost of the wheels and Tires
