Key won't come out of ignition 2004.5 S40
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
This topic is in the MVS Volvo Repair Database » Making My Volvo Faster
JulesB14
Year and Model:
Post by JulesB14 »
Hello, I recently noticed my check engine light come on while driving home from work. I have about 32,000 miles and just recently took it in for scheduled maintenance. I parked for about half an hour and then went to move the car and nothing will start. The engine doesn't turn over and no display lights come up. What actually bothers me the most at this point, is that the key will not come out of the ignition. As I was trying to get the key out (for about 5 min) all of a sudden the radio came on as did all the display lights. The automatic locks don't work and I don't really want to leave the key in the ignition all night before I can get a tow. Any suggestions would be great. Thanks so much!!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
Move the steering wheel back and forth while trying to get the key out (gently). Sounds like a classic case of the steering wheel lock mechanism blocking the ignition. Happens when the wheel is turned sharply, or the front wheel(s) is on an uneven surface.
Also -> Amazon link
JulesB14
Year and Model:
Post by JulesB14 »
The steering column is locked, but the wheels are straight and I am parked in my level driveway. Could this be an electrical issue? The car is still under warranty, I'm just kinda curious as to what is going on. I haven't had any issues with this car before, and I absolutely love it. Thanks for the help!
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
If you have your radio code, try disconnecting your battery for 20 minutes (that will tell you if it's electrical or not). Other than that and what's said above, I don't know what to tell you.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Make sure the shifter is in Park.
