Is there a low fuel warning light? 89 740 Turbo
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
johnboy740
Year and Model:
Post by johnboy740 »
Hi guys, neither the gas gage, nor odometer work on my 89 740. Is there a warning light that lights up when the tank is almost empty?
chn718
Year and Model:
Post by chn718 »
hi, I think that if non of your gauges are working that means the sensor is malfunctioning, you do have a low fuel light but because the gauges are not functioning correctly I doubt that the low fuel light well work. What I did was use the little trip calculator and said like fuel up every 250 miles or so. Hope this helps
johnboy740
Year and Model:
The odometer doesn't work, because the speedometer doesn't work. The trip guage doesn't work either. The guy I bought the car from said that there was a light and it worked, I was just checking if there really was a light or not because it doesn't come on and go off like all of the other warning lights when you first start the engine.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
This is from the 1989 owner's manual:
or when the fuel warning light (later models) comes on.
The '91 and '92 models have a different instrument panel to that fitted to your '89 model and there is a specific mention in the book about the low fuel light which is in the fuel guage.
However, as chn718 has stated a low fuel light will not work if the sender unit in the tank is out of commission as it draws its info from that unit.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
