95 850 turbo (non-R) crank no run
echosierra
Year and Model: 1995 855T
Re: 95 850 turbo (non-R) crank no run
Post by echosierra »
abscate wrote: 14 Sep 2019, 12:31 Fuel pressure needs to be right. Get that gauge sealed otherwise your measurement is meaningless. The fuel is metered by time , assuming a correct fuel pressure , so if this is 20% off the car won’t run
A 3 second blast of ether willl probably make it go vroom and can help confirm a fuel delivery problem
Good advice, will do
1995 855 Turbo
echosierra
erikv11 wrote: 14 Sep 2019, 12:05 ....125 is pretty low for compression if it isn't just the gauge, you expect 150-180. Lawn mower syndrome also possible at 125.
Wait, compression ratio on the turbo engines is 8.5:1, which puts in the 125 neighborhood right?
1995 855 Turbo
echosierra
Ok, fuel pressure = 46 psi with no leaks on the gauge
1995 855 Turbo
Has thanked: 292 times
Been thanked: 765 times
echosierra wrote: 14 Sep 2019, 13:21
Volvo actually puts the bottom of the range for this engine at about 155 and that's consistent with what people report, e.g. https://blog.fcpeuro.com/how-to-do-a-co ... linder-vol or https://volvoforums.com/forum/volvo-850 ... rbo-33048/ etc.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
echosierra
Please kids, buy quality tools, esp diagnostic tools. And listen to the experts here
After getting my hands on a good compression tester, my compression readings are:
1: 170
2: 170
3: 172
4; 172
5: 172
8) Measured cold and dry
1995 855 Turbo
Nice numbers! Well if you've tried swapping the crank and coil I've got nothing else. Immobilizer would be no spark.
'06 S60 R, 197k
echosierra
erikv11 wrote: 15 Sep 2019, 07:58 Nice numbers! Well if you've tried swapping the crank and coil I've got nothing else. Immobilizer would be no spark.
Crank sensor will be today, ill post results
1995 855 Turbo
Has thanked: 1505 times
Been thanked: 3817 times
Lets await the pending ether test, with bated breath (not baited breath - that's from fishing)
That will tell is if we are on the spark tree or the (fuel/spark) tree of Diagnostics
echosierra
Starting fluid test was easier than crank pos swap from the parts car, so that was first.
So staring fluid DID yield a ‘vroom’ for 2-3 seconds!
So this probably means that ive got a fuel problem? Right?
Pressure tested a couple days ago = 46 psi at the rail valve
I had the injectors sent off to be rebuilt when i first got the car a few weeks ago, maybe something went wrong there? But all 5 are bad? ...unlikely. Perhaps my injectors arent getting electricity/signal to fire?
What next?
1995 855 Turbo
You’ve got decent spark, yes.
Check for 12 volts at the injectors , you need a wiring diagram to get the right terminal
The injectors get a common 12 volts from the battery, and are fired by grounding through the ECU
If the 12 volts at the injectors is good and thefuel pressure is good, you have to inspect the wiring from injectors to ECU. They batch fire, all at once, I believe, in your software
