brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
abscate wrote: 15 Sep 2019, 20:10 Those gaps are huge, I’ll guess .045 inches.
I didn't even think to check the gap on the old ones, but I think I'll do that tomorrow!
This weekend, I drove the T5 about 230 miles to Hunter, New York, for a friend's birthday weekend, clocking in at 29 mpg by the time I got home. It would've been higher, except there was a crash on the Thruway that put me on the local roads for much of the drive up there.
Curiously, there were times when the car seemed to really fly while climbing hills at around 70mph and 2,300rpm and getting upward of 40mpg. It was awesome.
1998 V70 T5 in the wild
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Cookeh wrote: 24 Sep 2019, 08:23 Just wondering if a V70 tailgate will be a bolt-on swap, electrics and all, onto my 855? My 855s tailgate has some clearcoat failure, and some rust appearing on the leading edge. I've found a V70 tailgate in the correct colour for significantly less than it would cost me to repair/respray my current tailgate. I did have a search but could only find one post on the matter.
Are the two a straight swap? I know I have to get the bulb failure relay from the V70 too, as the relay for the V70s LED is different to that of the 850s halogen, but beyond that?
Cheers,
The latch MAY be different, but otherwise I'm pretty sure it's all the same. Physically I know for sure it will bolt on.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
bmdubya1198 wrote: 24 Sep 2019, 18:26
Cheers,
Thanks. Not overly concerned about the latch, can swap my 850 one on if need be, and I have an abundance of rivnuts if the bolt locations are different. I recall reading somewhere that the glass itself is different, and that somehow affects the heating elements? Any truth to this? I am not sure that source was particularly reliable but there is a surprising lack of info on swapping over what appears to be an identical tailgate.
Has thanked: 1502 times
Been thanked: 3817 times
The latch went through changes , I believe the 1999 was a two year only latch , for instance.
Rolled Elizabeth the T5 to Boston and back, 27 mpg at 65 mph, got back at 0001
bmdubya1198
abscate wrote: 25 Sep 2019, 02:54 The latch went through changes , I believe the 1999 was a two year only latch , for instance.
I think the '98-2000 latches are the same (at least from what the FCP Euro compatibility list says). The 850 latch may be different though.
Cookeh wrote: 25 Sep 2019, 02:38 Thanks. Not overly concerned about the latch, can swap my 850 one on if need be, and I have an abundance of rivnuts if the bolt locations are different. I recall reading somewhere that the glass itself is different, and that somehow affects the heating elements? Any truth to this? I am not sure that source was particularly reliable but there is a surprising lack of info on swapping over what appears to be an identical tailgate.
I haven't heard about the glass, but that's definitely something worth looking into. I couldn't imagine that it changed all that much, it could probably be modified to work.
Road trip...stop at IBM TJ WATSON research, the pick up a cherry picker inQueens, then Colimbia university for afternoon, culminating in seminar at end of day
Taconic very pretty drive, got off Manhattan by 6 pm , home by 9...no traffic? Wtf?
Pictures here
viewtopic.php?f=38&t=91184&p=519203#p519203
A dark 960 blew my doors off on the Northern end of the Taconic in the morning - whoosh...
Swore at removing the last bolt on the 1998 driver seat in a tight space, with a 14mm hex on a wobble, until I realised it was a manual slide seat and I could just slide it forward to get access.
#MrEvil
bmdubya1198
abscate wrote: 27 Sep 2019, 11:39 Swore at removing the last bolt on the 1998 driver seat in a tight space, with a 14mm hex on a wobble, until I realised it was a manual slide seat and I could just slide it forward to get access.
#MrEvil
Yep, been there! I'm used to working on power seats... manual seats are usually easier to work on!
Peevarino
Year and Model: 2009 XC70, 97 855R
Has thanked: 28 times
Been thanked: 3 times
Post by Peevarino »
FINALLY did the rear springs and shocks on my 855R. No more shot nivo. Mostly got everything apart easily, getting the ipd HD springs in was a pain
ETA: pretty sure I put one of the coil springs in wrong. On a drive to the grocery had a particularly loud noise going over a bump. One spring looks like it’s hanging up on the lower spring cup edge. Guess I need to jack up the car and try to rotate it a bit.
ETA again: I did put one in wrong. Fixed it, no noise, sits at same height on both sides.
09 XC70 3.2
97 855R
Has thanked: 292 times
Been thanked: 765 times
Partially stuck caliper RF on the 96 NA wagon. Some co-workers were driving it all summer, they didn't notice anything but when I drove it yesterday I immediately recognized metal-on-metal. Disc is not flat but not ruined. Factory caliper slide pines were dry but not corroded, I lubed up all four pins and put in some barely-used front pads I picked up on the forum. Beater car is back in business, just in time for fall/winter.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
