Ignition whine in speakers Topic is solved
vtl
Year and Model: 2005 XC70
Has thanked: 9 times
Been thanked: 110 times
Re: Ignition whine in speakers
Post by vtl »
Long ground wire is a source of the ground loop. To be of the same potential both the HU and Yatour would need to have an equally short ground wires connected to the same ground point.
Power in, power out and the ground, yes.
05 XC70, 16 XC60, 19 Tundra
P1+P2 CEM PIN-code retrieval DIY thread: viewtopic.php?f=10&t=85611
Yaworski
Year and Model: 2002 S60
Been thanked: 3 times
Post by Yaworski »
vtl wrote: Mon Sep 30, 2019 12:58 pmHave this one for power: https://www.amazon.com/gp/product/B0049MWUMQ It was DOA, but I was able to swap transistors and capacitor, so it works.
Would I put this in the power line for the Yatour box? The power line for the radio before the tap off to the Yatour? Or the radio power line after the tap?
Yaworski
Post by Yaworski »
vtl wrote: Wed Oct 02, 2019 10:31 am Long ground wire is a source of the ground loop. To be of the same potential both the HU and Yatour would need to have an equally short ground wires connected to the same ground point.
The Yatour doesn't have a separate ground wire. I think that it is grounded through the DIN plug.
vtl
Post by vtl »
Yaworski wrote: Sun Oct 06, 2019 2:29 pm Would I put this in the power line for the Yatour box? The power line for the radio before the tap off to the Yatour? Or the radio power line after the tap?
Between HU and Yatour, closer to Yatour.
I think I said that before, but I also had to break off the loop for line-in for my central speaker amp as well. The whine was minor, lot less than through ground, but still.
Yaworski
Post by Yaworski »
vtl wrote: Mon Oct 07, 2019 5:54 amBetween HU and Yatour, closer to Yatour.
Another question. Should I ground the filter directly to the car's chassis, the radio's chassis, or through the ground wire for the radio?
vtl
Post by vtl »
Yaworski wrote: Thu Oct 10, 2019 10:31 am Another question. Should I ground the filter directly to the car's chassis, the radio's chassis, or through the ground wire for the radio?
You do not need to ground it to the chassis.
Yaworski
Post by Yaworski »
vtl wrote: Thu Oct 10, 2019 10:52 amYou do not need to ground it to the chassis.
Just hook to the radio harness' ground wire?
vtl
Post by vtl »
Hook to Yatour's harness. Either splice the cable or make your own male-female adapter. Solder noise suppressor's ground wire to harness' ground wire, cut +12v wire, one end solder to green (input), another to red (output).
Yaworski
Post by Yaworski »
The Yatour doesn't have a separate ground. I'm guessing that it is grounded though the DIN plug and the the DIN's shell. So solder the ground to the DIN shell?
vtl
Post by vtl »
Solder black wire to the GND wire in the cable. The idea is to feed the +12v through the noise suppressor.
