Long ground wire is a source of the ground loop. To be of the same potential both the HU and Yatour would need to have an equally short ground wires connected to the same ground point.
Power in, power out and the ground, yes.
Ignition whine in speakers Topic is solved
Yaworski
- Year and Model: 2002 S60
- Has thanked: 5 times
- Been thanked: 3 times
Would I put this in the power line for the Yatour box? The power line for the radio before the tap off to the Yatour? Or the radio power line after the tap?vtl wrote: ↑30 Sep 2019, 12:58Have this one for power: https://www.amazon.com/gp/product/B0049MWUMQ It was DOA, but I was able to swap transistors and capacitor, so it works.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 604 times
Between HU and Yatour, closer to Yatour.
I think I said that before, but I also had to break off the loop for line-in for my central speaker amp as well. The whine was minor, lot less than through ground, but still.
vtl
Hook to Yatour's harness. Either splice the cable or make your own male-female adapter. Solder noise suppressor's ground wire to harness' ground wire, cut +12v wire, one end solder to green (input), another to red (output).
Yaworski
The Yatour doesn't have a separate ground. I'm guessing that it is grounded though the DIN plug and the the DIN's shell. So solder the ground to the DIN shell?
