07 S40 starter
gogoat
Year and Model: 2007 S40
Post by gogoat »
How do I remove the starter. There is a "click" from the starer but it will not turn over.
The air box looks like a job to get out first. New to Volvos but I fix all my own cars. These things are different for sure. Lot of special tools needed. Not sure if I am sold on them yet.
The 2007 S40 I have is in great shape though. 114K with engine and turbo at 76K.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
gogoat wrote: 31 Oct 2019, 15:24 How do I remove the starter.
1. Remove ECM.
2. Remove MAF.
3. Remove Air cleaner housing.
4. Remove Starter.
Active
Past
gogoat
Post by gogoat »
Thanks for this, those are some detailed illustrations. The engine is the 5 cylinder solid cam version. Nice power.
Sardine
Year and Model: V70 2.5T 2004, S60 2
Post by Sardine »
Hi, where can I buy that fantastic manual for a 2005 V50? I bought a manual online with details just like that a few years back for a VW Golf from factory-manuals.com. They do not have any for Volvo though. My Haynes V50 manual graphic is very hard to understand.
RickHaleParker
Sardine wrote: 17 Jan 2020, 20:34 Hi, where can I buy that fantastic manual for a 2005 V50?
You don't need to buy it. Go here read at least pages 1, 6 & 16.
Active
Past
gogoat
Post by gogoat »
I just want to say thanks for the help. Awile back I used the pics to help me fix the issue. I never did get the air box out, came to the conclusion that the engine needs jacked up a bit to get it off. But I did see the bolt for the 12V wire was loose. Tightened it and it fixed the issue, THANKS.
Another problem, might start a thread on it. Same car is leaking water on the driver side floor board. Factory sun roof car. Its a nice car and want to keep it that way. Where are the typical places to look ? I know jettas had a drain tube for the sun roof that would cause problems if plugged. Does this car have one ?
RickHaleParker
gogoat wrote: 17 May 2020, 20:18 Does this car have one ?
The front drain hoses runs down the A pillars. If it fails the water drains on to the floor. Take the cover off the inside of the A pillar and check the hose.
Active
Past
