OK, Got It. GLOVES! Thanks.tyguyc wrote: 05 Nov 2019, 10:04Indeed. and also Indeed.
I used purell, not that it really matters. and took two paper towels to get everything off my fingers.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
If you use Akebono ceramic brake pads you will practically never have to clean your wheels again (at least not of brake dust).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- tyguyc
- Year and Model: 2004 xc70
But what if you like cleaning the brake dust off your rims? What produces the most brake dust? and wont chew through rotors?E Showell wrote: 05 Nov 2019, 13:25 If you use Akebono ceramic brake pads you will practically never have to clean your wheels again (at least not of brake dust).
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
My Spanish made Bosch pads certainly seem to do the trick so fartyguyc wrote: 05 Nov 2019, 13:41But what if you like cleaning the brake dust off your rims? What produces the most brake dust? and wont chew through rotors?E Showell wrote: 05 Nov 2019, 13:25 If you use Akebono ceramic brake pads you will practically never have to clean your wheels again (at least not of brake dust).
ATE Ceramic pads are on the list for next time anything needs replacement. Or by spring. Depends a bit on how long I think I'll keep the car. Though there really isn't anything wrong with it and anything to match it's power/weight ratio is going to be either expensive or as old.
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
Started LCA, Ball joint, Inner & Outer tie rods today on my '06 V70. Went with all Lemforder parts except inner tie rods (TRW). Broke down one side, taking the struts out will make job a little more roomier. Rear LCA (hockey puck) bushing shot, as well as tie rod end. I think I read somebody used 2" PVC pipe for installing ball joint, it does fit perfectly over ball joints boot protector sleeve. With one threaded end and 2" threaded galvanized cap for pounding on, it just might work.
- Has thanked: 1613 times
- Been thanked: 4078 times
Press available up in the North Country if you get stuck (or your balls, I mean, Ball joints)
Route 32, just South of Albany
- GlennG2759
Thanks abscate, I'm about 50 mins. south of you and I might take you up on that. I just sent my daughter to get parts for PVC try. I'll let you know.
Glenn
Glenn
- MoVolvos
Great job Dad, teaching your daughter to be handy!GlennG2759 wrote: 06 Nov 2019, 15:45 I just sent my daughter to get parts for PVC try. I'll let you know.
Glenn
- GlennG2759
Iinstalled new ball joints in steering knuckles on my '06 V70. Used 2" by 4" galvanized pipe with cap, worked perfect. About half dozen shots with a 5 lb. hammer and they were home.
- 12198 Replies
- 1684776 Views
Last post by RedBrickCollector
- 97 Replies
- 210475 Views
Last post by br0dy519
- 59 Replies
- 62551 Views
Last post by smacknab
- 7109 Views
Last post by xHeart
- 12349 Views
