1998 S70 T5M 240k the Road to Stage 0
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Reviving my original topic to further document my repairs and the journey of getting my beloved T5M up to stage 0. Since I now only have one car to work on, it seems like I should work on it.
Completed repairs that I remember:
  • new rear rotors and pads
    original airbox reinstalled
    turbo vacuum lines fixed
    various little interior fixes
    new washer nozzles and disconnected headlight washers
    new fog lights
    All rubber brake hoses replaced and new front calipers
    fuel pump relay
    heater core
    new headlights
    probably some other stuff, but I've done a bad job keeping track
What's currently broke that should be fixed: (yes I've been living with most of these problems since 2016)
  • Cruise control
    hand brake
    coolant leaks
    exhaust leak / painfully loud exhaust
    clutch
    rear main seal
    headliner disaster
    windshield
Edit: Can a Mod change the title of the thread?
Edit: Added more repairs I forgot.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Two things concern me on your to do list: rear main seal and coolant leak. Have you done the glove test to determine the state of your PCV system? If not, you might want to. A clogged PCV system could produce the rear main seal leak. Otherwise, add some ATP 205 seal conditioner to the crankcase. That may help. Coolant leak. You may have a leaking heater core. Does it take a long time to defrost the windshield? Is there a faint sweet smell ( maple syrup-like) when you turn the heater on, or a mysterious film on the inside of the windshield? If so, you are due for a heater core replacement.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 4068 times
Can you tell me the desired title please?
If you are close to me I can help with that clutch job
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
abscate wrote: 31 Jul 2016, 05:04 Your cruise control is vacuum actuated and that sounds like a. Bad hose or leaking vacuum in that System. I think it lives under the battery in your car
Replace ALL your soft vacuum lines and elbows. If they aren't bad now, they will be soon. Use silicone replacements if you plan on keeping it. Cheap insurance.
E Showell wrote: 31 Jul 2016, 15:40 I was under the belief that turbo=synthetic oil, no?
Yes, always.
Edit: once again I respond to page 1 and after notice 7 more pages..... :roll:
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
Thanks for pedagogical reinforcement, Greg.
WhatAmIDoing
E Showell wrote: 05 Nov 2019, 03:08 Two things concern me on your to do list: rear main seal and coolant leak. Have you done the glove test to determine the state of your PCV system? If not, you might want to. A clogged PCV system could produce the rear main seal leak. Otherwise, add some ATP 205 seal conditioner to the crankcase. That may help. Coolant leak. You may have a leaking heater core. Does it take a long time to defrost the windshield? Is there a faint sweet smell ( maple syrup-like) when you turn the heater on, or a mysterious film on the inside of the windshield? If so, you are due for a heater core replacement.
PCV passes glove test. RMS has been leaking since 200k mi according to PO. First repair job I ever did was the heater core (added that to my list created from poor memory). But, I only replaced the heater core and the o-rings, not the heater hoses. Three leaks have now been identified: my new aftermarket lower rad hose, coolant bottle return hose at the clamp, and coolant puddling on the thermostat housing.
abscate wrote: 05 Nov 2019, 05:17 Can you tell me the desired title please?
"High Mileage '98 S70 T5M the Road to Stage 0"
Not close right now, but I can be. Clutch really needs to be done. Not sure how much longer I can baby it. I've got all the parts now, but I've been unable to find a garage to use while working on it (would rather not do it all outside by myself). Would be nice to have help at least.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Your 'new aftermarket lower radiator hose' may only need the clamp(s) tightened. Check if the hoses are fully engaged on the nipples and the clamp is not too close to the end of hose, but also not clamping on the barb of the nipple. Clamp torque should be tight. It is hard to explain needed torque - not all you can apply with typical screw driver handle, but more than just snug.
My apologies if you already know all this.
Added mileage to title and changed.
E Showell
Post by E Showell »
Try the ATP 205 in crankcase for RMS leak. You might get lucky. Lots to read about ATP 205 on this site.
'95 855 auto (sold)
Well, you have to yank/ drop the engine for the clutch,so that’s the time for the RMS
