So I have a bit of a dilemma.
I've been using a "rigged" clutch pedal for a few years since doing the manual swap on my 98 T5A (now T5M).
Want to order the correct pedal with the spring peg/pin actually on it so I can drive it correctly.
From what ive been told and seen, Part number 9173742 is what I want.
Well 9173742 is "discontinued".
From what I found searching online retailers, including volvopartswebstore, the part I should use is 9191520 which is in stock all over.
From what I can tell though, the 9173742 pedal fits 93-97.
And the 9191520 says it fits an engine break 98-04. (S70 CH 460000-)
I'm guessing here that the (S70 CH 460000-) is for internal slaves so it wont actually fit, but the picture looks correct that shows on their site.
Obviously before I order the newer number, I want to make sure it fits so I don't find out while im down there that is does not.
Any input or help would be appreciated.
Reason for buying from dealer - I have a gift card that expires at end of month/year and its December lol.
Spark notes:
9173742 (common 850 pedal used for 98 s70 manual swaps since 99+ wont work)
9191520 (apparently fits 98? but im worried it might be a 99 pedal since it also fits through 04 which means it likely wont work)
Car is a 98 s70 with M56H, external slave.
Thanks.
98 s70 clutch pin
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
