Motor Oil Type
PooYork
Year and Model: 2011 Volvo V50
Motor Oil Type
Post by PooYork »
I keep hearing conflicting opinions on the type of motor oil to put in my car. I cannot find a copy of my owners manual online so i was wondering if you guys could help me. I have a 98' V70 AWD with a Turbo. Thank you guys!! :D
1993 Volvo 940SE 200,000
1998 Volvo V70 118,000
2000 Volvo V70 126,000
1998 Volvo V70 AWD 155,000
2011 Volvo V70 110,000
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
5W-30 if you have cold winters (after the fall). 10W-30 for summer temperatures.
'98 S70 T5
2016 Chevy Cruze Premier
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
5w40 synthetic year round.
Ambitious but rubbish
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I use 10w40 in the summer and 10w30 in the winter.
Here's the owners manual : http://www.volvocars.com/us/top/yourvol ... fault.aspx
jblackburn
From said manual:
Really your choice. Just don't use a 15W or 20W, and don't use a -50. :)
You can stick with a good quality conventional oil (stick with the 30 weights for those) or a 40 weight synthetic oil if you choose. The bigger the difference in weights between the two on conventional oils (e.g. 5W-40) means they do not hold their advertised viscosities as well after a few thousand miles.
'98 S70 T5
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Been using Swepco 306 over a dozen years on various makes. Independent Volvo uses it.
http://www.yelp.com/biz/independent-vol ... lnut-creek
Swepco 306 15-40W once a year for myself in CA (10~12K miles) but if you have freezing weather 5-30W winter 15-40W summer.
http://www.pelicanparts.com/catalog/sho ... detail.htm
Try this one hundred miles after an oil change and feel, hear and drive the difference. This will give you an idea what the motor oil is like. It does not deteriorate like conventional nor synthetic so no clacking nor used motor feel.
http://www.pelicanparts.com/catalog/sho ... co_pg6.htm
The Swepco 714 20W Transmission Fluid has saved many a transmissions
http://www.pelicanparts.com/catalog/sho ... o_pg10.htm
http://www.bobistheoilguy.com/forums/ub ... mber=77240
EXCERPT - From First Time User Last Post on Page 2
"OK Folks...
Here are my first impressions/-seat of my pants-observations on the Swepco (mostly) 5W30. So far its been >500km and 10 days. The engine is running quieter at any cruising speed, all I hear is wind/road noise. (IT IS THAT QUIET - :D ) Start up is quick and the rough idle is gone. Fuel consumption seems to be a tad better (gas gauge), I will have hard numbers after a few fill-ups.
As for the piston slap.....
It has changed......
It is now clear, clean, crisp, somewhat like well tune castanets....I've never heard so well...
Stay tuned for more info.
Jean"
tmm657
Post by tmm657 »
So the sweep Co 306 oil on the pelican site says not recommended for catalytic converters. Anyone know what happens to converters?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
tmm657 wrote: 09 Dec 2019, 16:43 So the sweep Co 306 oil on the pelican site says not recommended for catalytic converters. Anyone know what happens to converters?
Probably has high amounts of zinc for classic cars with pushrod V8 engines with flat lifters to prevent camshaft wear. It clogs catalytic converters if the engine passes oil into the exhaust system for any reason. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
tmm657
Post by tmm657 »
Thanks June
tmm657
Post by tmm657 »
Alright, here is another question. Does anyone know if API service SN-RC ILSAC GF-5 is suitable for the 1998 2.4L turbo? It does not match specs in the owners manual, but I suspect it’s changed in the last 20+ years.
