Right, that’s the problem, of course,
I’m only cleaning half the connector, the other side is causing heat, and reoxidosing the fuse blade
Does anyone make an abrasive file the same thickness as a fuse blade to solve this?
- Has thanked: 1500 times
- Been thanked: 3812 times
- RickHaleParker
- Been thanked: 958 times
You might be able to fine a Jeweler or Watchmaker file that will fit. Filing is another band aid fix. It removes the top layer and make it more subject to corrosion.
A better option is to get a set of pin extractors, remove the terminal from the REM side and replace it. The tricky parts are figuring out which pin extractor to use, then sourcing a replacement terminal. However if succeed it is a permanent fix rather then a band aid fix.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Why permanent fix? Why won't the new terminal just oxidize?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
I would love to know root cause on this one. It’s the only car of 6 in the driveway that has this problem
- RickHaleParker
Permanent because the repair will out last the car.
Step one: Pin Extractor set. These are the tools used to compress the retaining clip(s) so the terminal can be pulled out of the plastic block.
A lighted Loupe comes in handy. For peeking into the connector to see the clips.
When I pulled the REM fuses everyone had the black corrosion on them. My best guess is there is moisture in the rear left wheel well ( wagon) that exacerbates fuse corrosion.
I did have some on my P80 relays once, after 15 years , and cleaned them too, but that hasn’t recurred.
viewtopic.php?f=1&t=80481&hilit=Albany&start=20#p434364
- E Showell
We'll, thankfully the weather held out and bro and I did the rear pads and rotors on the V70R having tackled the front brakes last weekend. Brembo and Akebono ceramic pads. Won't be cleaning the wheels for a while.
New windshield cowl seals for Ruby Red and new wiper blades for the '99 V70 and a rear wiper for the R as well (which also got a new expansion tank cap). Coolant looked a little low last week and I didn't like the look of the residue I saw on the tank near the filler neck.
'95 855 auto (sold)
'95 855 auto (sold)
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
Oophta x2.
1) That set of brakes set you back some pennies.
2) Keep a close eye on that coolant. Is this the same one you blew a head gasket on? Or was it a cracked sleeve? It’d be hard for me to not be doing compression & leakdown tests. What coolant did you run it it?
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- E Showell
Different engine. This is the replacement engine. Running Volvo coolant only. I'm thinking the coolant was evaporating out past a bad expansion tank cap seal.
The brakes weren't cheap, but the money I saved in DIY helped take a bit of the sting out. Plus, brakes are brakes. Can't do without 'em.
'95 855 auto (sold)
'95 855 auto (sold)
