CV axle skidding?
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Viskhard1
Year and Model: 2006 Volvo S40 T5
CV axle skidding?
Post by Viskhard1 »
Hello everyone.
I own a 2006 S40 T5 - Manual Trans. Around September, I changed both CV axles, seals, and front shocks. I refilled the lost oil with Lucas 75W90. Apparently, everything was ok. But little by little, a noise began to appear on the passenger's side. It only appears when the engine or transmission case is cold and when I am stepping on the gas when accelerating. Once is hot, the noise disappears.
I can describe this noise as if the gears slides, skids... as if there is no good contact.
Please, can anyone tell me what could it be? Can anyone give me a suggestion?
Thank you.
turtlehead
Year and Model: 98 Volvo T5
Post by turtlehead »
Are you sure that you installed the correct axle for this car? I had to replace mine and some places online didn't seem to recognize that the manual transmission uses a different size axle than the automatic transmission does.
Regards,
Tim
