Starter location on an S80 T6 3.2 L Topic is solved
petera58
Year and Model: 2009 S80 T6
Has thanked: 3 times
Post by petera58 »
Hello,
Can someone please help me determine where the starter is located on a 2009 S80 T6 engine. I'm attaching a pic of the engine.
Thanks a bunch!
view of engine
view of engine
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
The starter is at the back of the engine on the bottom.
A picture from my LR2 with the Volvo 3.2
Take care
Paul
petera58
Post by petera58 »
Thanks! I found it and appreciate the help!!!
pgill
Post by pgill »
No problem
Are you replacing the starter?
My 2008 LR2 starter died at about 100,000
My 2010 S80 is on the original starter at 135,000
Take care
Paul
petera58
Post by petera58 »
Yes, I took my old starter out to test it because I had replaced the battery on my vehicle and it wouldn't even turn over. I tested the starter with a direct hook up to my battery and a multi-meter and I was getting 12.5 volts to it but it wouldn't move at all.
petera58
Post by petera58 »
I have about 120k miles on it.
pgill
Post by pgill »
The Land Rover LR2 was based on the Volvo S80 when it was designed.
I own the LR2 and S80
A LR2 link that shows the starting circuit
Note: the S80 has a different configuration but I suspect that it has the same components
Look at the picture in this link. https://www.freel2.com/forum/topic33546-15.html
The key things that would prevent the starter from turning
- Fusable link by battery + connection
- Starter relay (sends power to the starter solenoid)
- Fuse for starter relay
- broken starter (worn out brushes)
Good luck
Paul
petera58
Post by petera58 »
So it turns out my AC compressor is seized up and that was preventing the engine from turning over.
pgill
Post by pgill »
petera58 wrote: 27 Jan 2020, 12:59 So it turns out my AC compressor is seized up and that was preventing the engine from turning over.
That is a very unique failure.
I've read about clutch pack failures for the AC and the compressor on my S80 lost its ability to cool the car.
But I've never hear about the compressor seizing and the pulley seizing (or clutch staying engaged) and then the engine won't start.
I am glad to hear that you found the source of the problem.
Thanks for sharing
Paul
petera58
Post by petera58 »
Thanks for all your help!
Now the fun really begins - changing out the ac compressor. My car is actually an 09 Volvo S80 T6 Sedan 4-Door 3.0L. I sent away for a repair manual from ebay that I'm hoping gives me details because I can't quite find the process for my engine on youtube or elsewhere. If those manuals work, I'll let folks know.
