Car died
- SuperHerman
- Been thanked: 207 times
Any lights? Can you hear the fuel pump? Any other information you can provide? Gas level sufficient?
- June
- Has thanked: 523 times
- Been thanked: 261 times
Check the positive connection under the hood. Had the starter cable go bad and fry the fuse panel it's connected to in my 2004 S80 T6. The car suddenly died while running normally and would not restart like the battery suddenly died. June
- 20200101_152531.jpg (151.75 KiB) Viewed 705 times
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Yes there are headlights, but after charging the battery it still drags when we try to start it, and it has a full tank of gas, and duel pump sounds like it is clicking on, but dont seem like its getting fire, also here a clicking noise when trying to start it in a silver box that im thinking is the ETM electronic throttle module i believe
- SuperHerman
Check your serpentine belt and make sure it is there. While having someone turn it over make sure the alternator pulley is spinning. When asked about lights - I was asking about check engine lights. It could be your alternator failed and you don't have enough power. Charging the battery and getting it started should result in a warning light and/or error message regarding electrical power.
As June suggests, checking your cables is a good idea - also power related.
If the car does not have enough power all sorts of computer systems will not function correctly - so battery and fuel is the first place I would look.
I have put a new battery in car but still drags whrn i try and start it, there are check engine and service engine lights that come im lost at whaT it could be, i dont have $ for a mechanic so hoping to figure it out. Thanks for all the imput
- SuperHerman
Check your timing belt - remove the cover and inspect. If it is intact and tight, try unplugging the MAF and see if it starts.
Without codes it is pure low lying fruit guesses.
- Has thanked: 1506 times
- Been thanked: 3822 times
Get the battery on a 10 Amp charger for a full day, then report back how it cranks (turning engine over with key) and if it trying to fire at all.
Usually, when they go suddenly, its an electrical fault of some kind, but it can be in main charging, starting, or even fuel delivery system.
