No crank no start
zg3001oe
Year and Model: 2005 v70
No crank no start
Post by zg3001oe »
I have a 2005 Volvo v70 suffering a no crack no start. I replaced the starter and still had the issue. Battery is good. Park neutral switch is good. Took it to my mechanic and he said it was the ECM. He showed me that I could start it by using a relay test switch in place of the starter relay with the key in the on position. When doing this it runs perfect. I think it may be the key. Do you guys think it's the ecm or do you have any other ideas? Thank you for the help.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
You may be right about the key - I don't know. Stand by and some more-knowledgeable-than-I folks will likely offer suggestions. In the mean time I think I can safely say DON'T let the guy start messing with an ECM replacement without first doing some exhaustive diagnostics. A drastic move like that could send you down a VERY expensive road.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Can you show your VIN?
zg3001oe
Post by zg3001oe »
Its yv1sw612852507714
yagger
Post by yagger »
In your case:
if you have a manual transmission, push the clutch pedal before start engine...
also, check RELAY FMA4 in the fusebox under hood.
If your engine started when you activate that relay directly, this means there is problem with this relay (FMA4), wires from CEM to relay or with CEM module.
FMA4 Relay.png (39.15 KiB) Viewed 3122 times
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
yagger - most impressive. You really know your stuff. Thanks for your valued input.
yagger
Post by yagger »
:oops:
zg3001oe
Post by zg3001oe »
Thank you for the help yagger. I will check and let you guys know
zg3001oe
Post by zg3001oe »
Hello all. Checked the relay and that was not the issue. Put a new one in and still have the same problem. My mechanic said something specific about the ground with the ecm. And it not communicating with the key. And I can turn the car off with the key when using the bypass switch. Any other thoughts?
yagger
Post by yagger »
If there are some issues with communications, best way to show here couple screenshots from VIDA tabs, like Network and Errors.
