Amazon Cyber Monday 2020
Volvo Findings! (What have you found on Craigslist?)
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 43 times
Been thanked: 98 times
Post by MoVolvos »
- Pete - wrote: Wed Feb 12, 2020 11:42 pm
MoVolvos wrote: Mon Feb 10, 2020 3:20 pm 16" VOLVO WHEELS (5X108) - $100
https://greenville.craigslist.org/wto/d ... 71643.html
I've been pondering a set of those for sale up here Ben.
Never seen a set of them on an XC or V. Surely would look better than the corroded, curb-checked, flakey-paint clunkers (barely) hanging onto my hubs.
I think you'll like these more Pete.
https://raleigh.craigslist.org/pts/d/wi ... 00056.html
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Has thanked: 124 times
Been thanked: 349 times
MoVolvos wrote: Thu Feb 13, 2020 6:11 pm
Are you sure the offset is ok for older cars? I think not.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
MoVolvos
Post by MoVolvos »
erikv11 wrote: Thu Feb 13, 2020 6:18 pm
I did not compare but I've been using this excellent website to check Wheel Fitment.
https://www.wheel-size.com/size/volvo/xc90/2019/
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
MoVolvos
Post by MoVolvos »
Which would you buy all things considered in terms of cost of ownership and ease of DYI? Am considering purchasing one of these. The 2011 XC60 has the transmission and P0430 problem. Owner purchased for daughter in Nov. 09 so don't know if it is consuming oil and causing the P0430 for the CATS. Was thinking of the Scotty Kilmer Lacquer Thinner Trick might fix the P0430.
2006 VOLVO XC90--2.5T--AWD--SUNROOF--139K MILES--GRAY - $3688
https://charlotte.craigslist.org/ctd/d/ ... 12122.html
2011 Volvo XC60 - $3200
https://greensboro.craigslist.org/cto/d ... 12049.html
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
MoVolvos wrote: Thu Feb 13, 2020 6:30 pm
That's a great site!
The site confirms that the newer wheels will not fit a P80 car without modification and adapters, personally I wouldn't bother although I also agree those are nice looking wheels.
The offsets are manageably different: 50mm for the new wheels vs 43mm for the P80
The center bore differences preclude using the new wheels on a P80 without boring them out: 63.4mm for the new wheels vs. 65.1mm for the P80
'96 855 NA, 145k
'06 S60 R, 167k
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 49 times
Been thanked: 195 times
Post by bmdubya1198 »
MoVolvos wrote: Thu Feb 13, 2020 6:07 pm Who wants to save this? Should be still intact.
https://greenville.craigslist.org/cto/d ... 80584.html
I can understand that he wants a return on those parts, but $1k for a parts car? Yeah, no. That's a $500 car tops. People don't seem to understand that parts they put into a car (namely tires) don't raise the value... especially when it can't be driven home.
'00 V70R Venetian Red/Charcoal M56 Swapped 200k
'03 S60 2.4T Silver/Black 118k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
'98 V70 GLT Black/Beige 205k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
bmdubya1198
MoVolvos wrote: Thu Feb 13, 2020 6:38 pm -
I'd lean towards the XC90 for ease of repair and ownership cost. The 3.2 in the XC60 is a good engine from what I've heard, and not terrible to work on (again, just from what I've heard), but I know for a fact the 2.5T is very easy to work on. It's a 2006, final year for the 5 cylinder XC90, so it's probably the best year to have.
The AWD system requires a little attention, but it's nothing bad. I'd recommend replacing the AOC fluid and filter if it hasn't been done to keep the pump and DEM in good shape. Otherwise, the AWD is pretty reliable and low maintenance.
The 3.2s are known for oil consumption and have been known to have issues with the READ. Being a 2011, it likely wouldn't have any problems with the READ but the possibility of consumption issues still exists. Probably not anything unrepairable (PCV getting clogged is common, and much easier to repair than the white block PCV) but I just don't know enough about them.
'99 BMW 528i
'01 Mountaineer 5.0
Considering only ease of DIY there is no question - the 06 hands down. Cost of ownership probably a wash but unpredictable.
Overall I'd also go with the XC90 unless you specifically want a small car (XC60) or one that is already problematic.
'96 855 NA, 145k
'06 S60 R, 167k
MoVolvos
Post by MoVolvos »
Thanks for the input (bmdubya1198, erikv11). I'm leaning towards the 2011 due to it's never and safer features. From looking at reviews on Youtube it drives like a car. Wife want reliability and ease of repair so the XC90 is probably the better choice.
The XC60 does have new Michelins whereas the XC90 new Westlake tires :cry: . If only I could get my hands on it to see if I can cure the P0430 with lacquer thinner and do a flush on the tranny? In terms of cleanliness I think the XC90 is in great condition from the pictures.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
MoVolvos
Post by MoVolvos »
erikv11 wrote: Thu Feb 13, 2020 7:38 pm
Great site but now I'm spending time looking at rims :? !
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
