Any tips to get lower oil line off the radiator?
JimBee
- Has thanked: 25 times
- Been thanked: 42 times
Re: Any tips to get lower oil line off the radiator?
I think I used a little assembly grease to hold the rectangular o-ring in the t-stat housing while reassembling.
TheOtherside
- Year and Model: 1998 V70R
- Has thanked: 55 times
- Been thanked: 5 times
Still no luck... looks like I'm looking for a radiator. Lol.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- Has thanked: 1505 times
- Been thanked: 3817 times
Disconnect the oil line at the cooler, get the radiator out and onto the bench where you can really get at it. If you don’t want to stump up for a new one, renewal the fasteners so the future radiator job will be easy
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
Btw, Is there a writeup here on the oil thermostat? I think I will have to remove mine also pretty soon.
850 T5-R '95 auto
Be very careful with that, they are no longer available as new partshausmeister wrote: ↑16 Mar 2020, 06:54 Btw, Is there a writeup here on the oil thermostat? I think I will have to remove mine also pretty soon.
hausmeister
Exactly, not sure if I can remove it? Is it within the rectangular splitter, or is it one unit? I will have to take it apart to replace orings/seals I guess. If I can I'd remove it at the time.
850 T5-R '95 auto
TheOtherside
Good idea! I'll start picking at it!
Any radiator removal threads?
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
TheOtherside
Started draining the radiator and removed some hoses for now.
I'll pick at it more after work.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
hausmeister
What I remember it is quite straigthforward. Start at the top with the relais, cover, dipstick tube...Any radiator removal threads?
I think you also have to seperate the AC rad, then there are 2 mounts to unscrew from the bottom, which can be a bitch if the crimped on nuts break lose.
Not sure if you have to take the Intercooler out with it, but I think so (if you have one).
850 T5-R '95 auto
Yep it has an intercooleR
Get some PBB on the two Radiator M8 bolts on the ears - those are usually nasty.
