Any tips to get lower oil line off the radiator?
Has thanked: 1505 times
Been thanked: 3818 times
Re: Any tips to get lower oil line off the radiator?
Yes, it’s a
Ac conensor
Intercooler
Radiator
Sandwhich
TheOtherside
Year and Model: 1998 V70R
Has thanked: 55 times
Been thanked: 5 times
Post by TheOtherside »
98 V70R
13 Flex w/EcoBoost
Has thanked: 292 times
Been thanked: 765 times
TheOtherside wrote: 17 Mar 2020, 12:46 This was NOT fun...
Putting it back in is going to be worse...
I'm loving that pile of wrenches on the RHS of this pic. Keep at it man!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I have used a hammer for 45 years now but you got me on that one ... :shock:
1999 V70 GLT
TheOtherside
Lol thanks guys!
Is this broken?
98 V70R
13 Flex w/EcoBoost
TheOtherside
Been beating the ever living F&&$&$*#*#*@*?×[["&"*K out of this thing....
It wont budge.
Also pretty sure the part the line threads on to is broken...
98 V70R
13 Flex w/EcoBoost
The part in the radiator is ok, but you need to get the line out of the attachment which threads on.
Wow. Maybe a new oil line is needed. You might have to cut that piece to get the line off
That looks the same as my spare Nissens , I can send you that piece. New oring and you should be good to go.
Internal pictures here..,, search by part number rocks!
viewtopic.php?f=1&t=79799&hilit=Nissens ... nal+cooler
TheOtherside
abscate wrote: 18 Mar 2020, 00:40 The part in the radiator is ok, but you need to get the line out of the attachment which threads on.
Man, you're too nice! How much do you want for it?
98 V70R
13 Flex w/EcoBoost
Sveedy
Post by Sveedy »
You could try soaking it in a solution of acetone and ATF. Works surprisingly well...
1999 V70 GLT
Has thanked: 1850 times
Been thanked: 1710 times
The oil coolers are built inside the end housings. There are seals between the housings and the plastic end housings to seal them. I had issues with a leak at that point at one stage and a radiator shop was able to fix it and pressure test to prove it was then water tight.
