Yes, it’s a
Ac conensor
Intercooler
Radiator
Sandwhich
Any tips to get lower oil line off the radiator?
TheOtherside
- Year and Model: 1998 V70R
- Has thanked: 55 times
- Been thanked: 5 times
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- Has thanked: 311 times
- Been thanked: 817 times
I'm loving that pile of wrenches on the RHS of this pic. Keep at it man!TheOtherside wrote: 17 Mar 2020, 12:46 This was NOT fun...
Putting it back in is going to be worse...
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I have used a hammer for 45 years now but you got me on that one ...
1999 V70 GLT
1999 V70 GLT
TheOtherside
TheOtherside
The part in the radiator is ok, but you need to get the line out of the attachment which threads on.
Wow. Maybe a new oil line is needed. You might have to cut that piece to get the line off
That looks the same as my spare Nissens , I can send you that piece. New oring and you should be good to go.
Internal pictures here..,, search by part number rocks!
viewtopic.php?f=1&t=79799&hilit=Nissens ... nal+cooler
TheOtherside
Man, you're too nice! How much do you want for it?abscate wrote: 18 Mar 2020, 00:40 The part in the radiator is ok, but you need to get the line out of the attachment which threads on.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- Sveedy
You could try soaking it in a solution of acetone and ATF. Works surprisingly well...
1999 V70 GLT
1999 V70 GLT
- Has thanked: 2200 times
The oil coolers are built inside the end housings. There are seals between the housings and the plastic end housings to seal them. I had issues with a leak at that point at one stage and a radiator shop was able to fix it and pressure test to prove it was then water tight.
