broken downpipe
dneu
Year and Model: 2004 V70R
Post by dneu »
The downpipe on my 2004 V70R just broke off right from the flange connected to a turbo. Does anyone have any experience with welding it? I cannot find anywhere a reasonable replacement for less than $ 1200. Thanks.
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Wow, can you share a photo of it?
Did it break off AFTER the DP flange weld?
Is it the original DP?
If so, chances are it’s pretty crusty & you’d have an extremely hard time getting clean metal, and then it would also be unguaranteeable as far as the quality & longevity of the fix/weld.
These things get red hot.
I think you might be best off looking at an aftermarket DP. There are companies that make DP’s w/catalytic converters for under $500. No CEL for cat efficiency codes (downstream O2) and your turbo spools up quicker.
Snabb catted downpipe
RE-VOLV catted DP
I have 2 of those ^^^, one catless & one catted.
EuroSport Tuning Mototec DP
I’ll be installing one of these ^^^ today.
If you end up going with an aftermarket/larger diameter DP you will eventually want to get your ECM flashed for proper tune.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Not needed, but you will reap the benefits more with a tune. I replaced the whole stock exhaust with stainless
BSR Tuning 3" downpipe with 200 cells cat + Rakaror 3" resonated catback.
ImageBSR 3" Downpipe with Sports Catalyst by Andy Ramdin, on Flickr
Catalyst closeup
ImageVolvo S80 2.4T 3" BSR Downpipe (Inside view) by Andy Ramdin, on Flickr
Old vs new, new downpipe comes with an extension cord for the secondary O2 sensor
ImageVolvo S80 2.4T 3" BSR Downpipe by Andy Ramdin, on Flickr
Modded catback vs Rakaror 3" catback
ImageVolvo S80 2.4T Rakaror 3" Stainless Resonated Catback by Andy Ramdin, on Flickr
How it sits under the car (I wanted to keep the stock look)
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Welding is very difficult because it's rotten and because it must keep the flange angle or the flexible will be under stress and fail soon after. Clearly a job for a very skilled exhaust place. But as above, there's aftermarket options, search on Ebay, however some may throw a check engine (cheap cat), may fit poorly (this will also quickly cause the flexible to leak) and also if you have emission inspections I don't think cheap ones will pass
