What is this part, what does it do?
Clawhammer
Year and Model:
Post by Clawhammer »
Hello. I recently bought a 1996 850 GLT wagon with 68k miles on it. It is for my 16 year old son to drive. I also want him to learn some basic under the hood work. It needs a new thermostat so I plan to replace it this weekend but I just noticed a part that looks like a cover is missing. It sits on the firewall just under the hood and is a circular object maybe five inches across. I circled it in the image.
What is this thing? What does it do? Should it be flat with a long post in the middle, should it have a slightly rounded or bell shaped cover with a nut on it, is it fine the way it is? This is not an image of mine but one I found on the web. I will try to get a picture of it if necessary.
Jeff
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
That is the horn for the alarm system. The face should be open.
Clawhammer
Year and Model:
Ozark Lee wrote:That is the horn for the alarm system. The face should be open.
Thanks Lee. I guess I was alarmed for no reason...
Post by Ozark Lee »
LOL
By the way, if that picture is of your car you need to order up a new cap for the radiator expansion tank. The gray caps all fail. The new formulation of plastic is a greenish color and they seem to hold up just fine. FCP Groton has them for $5.00.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Timing belt is WAAAAAAAAAAAAAAAAAAAAY overdue on time (7 years)
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Agreed! Rubber deteriorates over time and the timing belt is made of rubber.
Clawhammer
Year and Model:
LOL
This isn't a picture of my car but I will check tomorrow...
Clawhammer
Year and Model:
JRL wrote:Timing belt is WAAAAAAAAAAAAAAAAAAAAY overdue on time (7 years)
Not to worry. I have all the records and it was changed at 49k. I thought it was early but maybe it was the years and not the miles that caused them to change it.
Jeff
MadeInJapan
Jeff,
Just keep up with the miles since it was changed. 7 years is max on these belts. The next change also needs the tensioner.
nctlspider
Year and Model:
Post by nctlspider »
Guess you never owned a motorcycle :D
First thing i thought when i saw that in mine was....Oh someone moved the horn! But i mainly ride bikes and its been over a year since my last car.
1996 855 Base with over 230,000+ unknown miles
5 Speed Std. Trans.
