Could it be a bad starter relay? I probably have a handful of junkyard relays floating around. Who knows, one could even be a starter relay.
Is the starter on a dedicated relay, or would I be losing other stuff as well if the starter relay were bad?
'99 V70 FWD, Auto, Base, 235K miles -- Toasted PNP? Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- RickHaleParker
- Been thanked: 980 times
Bosch MSA is engine management for diesel.
Bosch MSA was used in Volvo Cars with Audi engines.
Active
Past
Past
- RickHaleParker
Yes, Yes and No.E Showell wrote: 28 Mar 2020, 16:07 (1) Could it be a bad starter relay?
(2) Is the starter on a dedicated relay,
(3) or would I be losing other stuff as well if the starter relay were bad?
Active
Past
Past
- E Showell
Thanks Rick. Replaced "J" relay with one I had in inventory so either I have 2 bad starter relays, or the ignition switch electrics are bad.
Depending on the chassis break number, I have an extra ignition switch, electrical side, in inventory as well.
'95 855 auto (sold)
'95 855 auto (sold)
- RickHaleParker
Also:E Showell wrote: 28 Mar 2020, 17:38 Thanks Rick. Replaced "J" relay with one I had in inventory so either I have 2 bad starter relays, or the ignition switch electrics are bad.
1. Could be wiring and/or connectors between ignition switch and starter relay.
2. Could be wiring and/or connectors between fuse 11A/3 and starter relay or fuse 11A/3.
3. Could be column lock on the fritz, not letting the key go all the way to POS III.
The Yellow-White wire at the ignition switch and starter relay should switch on and off with key POS III. If it does not at the ignition switch the problem is on the steering column.
Active
Past
Past
- Has thanked: 1613 times
- Been thanked: 4075 times
That’s terminal 2 on that J relay. It should go to 12 V relative to an engine ground when key goes to pos III
- E Showell
Success. Problem was perished ignition switch electrics. Thanks Steve.
'95 855 auto (sold)
'95 855 auto (sold)
- 17 Replies
- 3754 Views
- 697 Views
Last post by mayorpeoria
- 139 Views
Last post by misha
- 921 Views
Last post by oragex
- 207 Views
Last post by E Showell
