Wiper issue - no park, no intermittent sitting
Has thanked: 1507 times
Been thanked: 3823 times
Re: Wiper issue - no park, no intermittent sitting
When you select pos 3 on the switch
Terminal 2 and 5 should connect with continuity
Terminal 1 and 3 should connect with continuity
You can use the beep function or ohms , lie scale to test those.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
To test Cam switch:
1. Set multimeter to 20 volt range.
2. Place + lead on the wiper motor's green wire.
3. Place - lead on the wiper motor's yellow-violet wire.
4. Turn on the wipers.
You should see 0 Volts with one 12 Volt pulse per cycle of the wipers
