car starts without cam sensor? testing
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
wanting to test the different sensors on my 2001xc70, i removed the cam sensor on the back of the engine and tried starting and it started...question is should it, is the sensor faulty??.
2001 XC70 factory M58
2002 XC70 auto (parts car)
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
darrylrobert wrote: 05 Apr 2020, 04:10i removed the cam sensor on the back of the engine and tried starting and it started.
If the ECM cannot detect the camshaft sensor it uses a lookup table. The engine will run but it will not be optimized.
darrylrobert wrote: 05 Apr 2020, 04:10...question is should it, is the sensor faulty??
What does your diagnostic scanner say when the camshaft sensor is plugged in?
Active
Past
darrylrobert
thanks i will check scanner.
