car starts without cam sensor? testing
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
wanting to test the different sensors on my 2001xc70, i removed the cam sensor on the back of the engine and tried starting and it started...question is should it, is the sensor faulty??.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- RickHaleParker
- Been thanked: 980 times
If the ECM cannot detect the camshaft sensor it uses a lookup table. The engine will run but it will not be optimized.darrylrobert wrote: 05 Apr 2020, 04:10i removed the cam sensor on the back of the engine and tried starting and it started.
What does your diagnostic scanner say when the camshaft sensor is plugged in?
Active
Past
Past
- darrylrobert
thanks i will check scanner.
- 19 Replies
- 5524 Views
- 23 Replies
- 2633 Views
- 1296 Views
Last post by volvomadness
- 806 Views
Last post by MadeInJapan
- 1766 Views
Last post by doublebug
