Thank you members for all the troubleshooting guidance. I will check and reply...
1. Ether
2. Fuel pressure
3. FPR
4. Cap/rotor (with images for Apl users) Note: Cap is OEM Bosch 17K miles.
Codes: P0440 and P0455
Engine died while driving and won't start. Topic is solved
- valvolvo70
- Year and Model: 1998 V70 T5 249K
- Has thanked: 10 times
- Been thanked: 8 times
- Has thanked: 316 times
- Been thanked: 531 times
Gotcha, so no other DTCs. I've had many cases lately where I'm diagnosing something like this with no DTCs at all.misha wrote: 06 Apr 2020, 10:08 Just Evap codes for years...but now...we confirmed that purge valve was stuck open.
It normaly must be closed at rest untill ecu ask for it.
I'm waiting for results after the advice i have him.
- Been thanked: 4067 times
valvolvo70 wrote: 06 Apr 2020, 10:49 Thank you members for all the troubleshooting guidance. I will check and reply...
1. Ether
2. Fuel pressure
3. FPR
- valvolvo70
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Down and AFTER the Maf.
Closer to throttle body.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
You'll want to spray it in the throttle body itself, just remove the hose that goes into it from the intercooler outlet.
- valvolvo70
**UPDATE**
1. Ether- Didn't need as I was able to start it.
2. Fuel pressure- 40 psi prime key position ll. At the time of testing psi, it wouldn't start.
3. FPR- TBD
4. Cap/rotor (with images for Apl users) Note: Cap is OEM Bosch 17K miles.- See images I cleaned it.
Engine stumbling AFTER reaching temp. It ran great today, drove up/down my street until the engine reached temp.
Replaced EVAP purge valve, new OEM Bosch.
Codes: P0102 (I disconnected the MAF) and P0444.
I'm having the exact same issues as previously posted, here's the link...viewtopic.php?f=1&t=86966
![Image]()
3. FPR- TBD
- Has thanked: 2200 times
That looks like oil in the dizzy cap. You may have a leaking rear cam seal which allows oil into the distributor flooding it.
If you haven't already, do the rubber/latex glove test. Place the glove over the oil filler on the top of the engine while running and se if it inflates. If it does you have, then the crankcase pressure will blow out your cam and rear/front crank seals.
It could just be a bad cam seal but more likely crank pressure.
Fuel pressure should be 42 psi, but will probably be ok.
- valvolvo70
scot850 wrote: 05 May 2020, 15:43 That looks like oil in the dizzy cap. Yes, and condensation. You may have a leaking rear cam seal which allows oil into the distributor flooding it. I think so, Ive seen more oil leaking from the crank position sensor.
If you haven't already, do the rubber/latex glove test. Place the glove over the oil filler on the top of the engine while running and se if it inflates. If it does you have, then the crankcase pressure will blow out your cam and rear/front crank seals. I did last year while troubleshooting the same issues and it did inflate.
Fuel pressure should be 42 psi, but will probably be ok. I'll check again now that it's starting regularly.
If you haven't done the PCV yet, I recommend doing that very soon as well as replacing the rear cam seals.
- 1277 Views
Last post by FL850_1997
- 3611 Views
Last post by lummert
- 19 Replies
- 3948 Views
Last post by cn90
- 14 Replies
- 3468 Views
Last post by dj_v70
- 1565 Views
Last post by sleddriver
