S40 t5 Injectors
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
donutV70
Year and Model: 1999 V70
Has thanked: 9 times
S40 t5 Injectors
Post by donutV70 »
Hey i just had a question about fitment of injectors (black) out of a 2006 S40 t5 fitting into a 1999 V70 glt.
anyone have any ideas if this would work, just have some locally i can get cheap
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
no
BMW 540i 2002
S70 Base 2000
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
You can get a set of 5 correct Bosch injectors on eBay for ~$50.00. Bosch part number 0280155831. Remanufactured and flow matched. The flow match will get you better fuel economy and pay for themselves in fuel cost savings. This is a case where the right choice is more cost effective.
Has thanked: 1502 times
Been thanked: 3813 times
( erikv11 reply pasted here)
Reply:Are the injectors not working right on the 99?
If you are looking for some kind of performance upgrade by using T5 (HPT) injectors in your LPT car, it doesn't work that way. Higher flowing injectors just make the engine run rich, and the ECU will try to compensate to lean out the mixture. No performance gains are possible by only switching injectors. Instead it will run less well, unless you also switch the ECU tune.
Unfortunately, it won't work.
donutV70
Post by donutV70 »
Thanks guys, I was planning on picking them up for when I tune the car for a higher boost pressure and thought these might fit.
Any idea if the coil packs would fit, wouldn’t mind having some extras 😂
kallekula
Post by kallekula »
Look online at arbitrary parts supplier for each car you have and cross-reference the part#
BMW 540i 2002
S70 Base 2000
donutV70
Post by donutV70 »
kallekula wrote: 14 Apr 2020, 11:18 Look online at arbitrary parts supplier for each car you have and cross-reference the part#
Wouldn’t this only work if I was looking for injectors that are identical?
I’m looking for higher flow injectors as I plan on using a 15g, down pipe and tune
