Hey i just had a question about fitment of injectors (black) out of a 2006 S40 t5 fitting into a 1999 V70 glt.
anyone have any ideas if this would work, just have some locally i can get cheap
S40 t5 Injectors
- RickHaleParker
- Been thanked: 958 times
You can get a set of 5 correct Bosch injectors on eBay for ~$50.00. Bosch part number 0280155831. Remanufactured and flow matched. The flow match will get you better fuel economy and pay for themselves in fuel cost savings. This is a case where the right choice is more cost effective.
- Has thanked: 1497 times
- Been thanked: 3810 times
( erikv11 reply pasted here)
Reply:Are the injectors not working right on the 99?
If you are looking for some kind of performance upgrade by using T5 (HPT) injectors in your LPT car, it doesn't work that way. Higher flowing injectors just make the engine run rich, and the ECU will try to compensate to lean out the mixture. No performance gains are possible by only switching injectors. Instead it will run less well, unless you also switch the ECU tune.
Unfortunately, it won't work.
donutV70
- Year and Model: 1999 V70
- Has thanked: 9 times
Thanks guys, I was planning on picking them up for when I tune the car for a higher boost pressure and thought these might fit.
Any idea if the coil packs would fit, wouldn’t mind having some extras
- 1136 Views
Last post by precopster
- 412 Views
Last post by rspi
